89 Civic Battery light, then no start? "HELP"
Old May 1, 2005 | 09:10 PM
utahcoheed's Avatar
Default 89 Civic Battery light, then no start? "HELP"
Hello all! I am completely at a loss!! My 89 Civic 1.5 EFI will not start! it just cranks and cranks. Earlier in the day I noticed that the battery light would flicker at idle in drive. when in park the RPM would jump and the light would go off. I drove it around town with no real problems. I then went to leave McDonalds and it will not start!! just cranks and cranks.. I noticed the CEL does not have the "click" like it should when the main relay gives power to the pump. I am almost sure that the no start is due to a faulty Main relay because of the symptoms and the no "click" but... the battery light also scares me, could it be an ignitor coil? or alternator causing it not to start? when we try and jump it has plenty of power just wont fire.. Any wisdom on this issue would realy be help! Can a main relay cause a battery voltage light light???? thanks so much in advance for any infomation!!!!
Old May 1, 2005 | 09:36 PM
utahcoheed's Avatar
Default Re: 89 Civic Battery light, then no start? "HELP" (utahcoheed)
Bump.. Thanks
Old May 1, 2005 | 09:39 PM
Immanuel's Avatar
test your alternator, and SEARCH there is a very similar thread created 2 days ago, I forgot the tittle though
Old May 1, 2005 | 09:51 PM
utahcoheed's Avatar
Default Re: 89 Civic Battery light, then no start? "HELP" (1.6 DOHC ED9)
Thanks I did try searching and found some great threads on "main relay" one of my main questions is if a main relay can cause a battery check light?
dustin sterner
Jul 31, 2017 07:15 PM
t_mac
20
Dec 9, 2008 03:29 PM
Silver03
Honda Civic (2001 - 2005)
Oct 7, 2006 09:35 AM
utahcoheed
May 2, 2005 08:56 PM
