Need a GSR Crank!!
I've got one for sale.
It's a P72 crank that has had the journals micropolished and the oil holes chamfered. The balance was checked and it was good, so none of the counterweights had to be drilled.
$150 went into the balancing, micropolish and chamfering.
The main journals measure:
(1) 2.1646" - 2.1645" - 2.1643" - 2.1647" to 2.1648" - 2.1645" (5)
The only oddity is that the #4 main journal is slightly bigger and, for me, it meant that I had to use another crank in my block since an OEM Honda red bearing still couldn't give me the tolerance that I wanted. I switched to using the other crank I had instead of spending the money to have the journal polished down another two to three ten-thou's.
It might clearance fine in whatever block you use because it clearanced fine with a brown or green bearing in the other block we had. It just depends on the block.
I never got around to measuring the rod journals, but I can do that if you want.
Asking price is $275 + S&H.
It's a machined P72 block from a JDM GS-R (B18C).
Nothing milled off the deck, and the mains were never align bored.
The only thing that's been done is a .25OS bore, but it probably needs to be honed and finished honed again since there's a little bit of oxidation happening at the top of the bores.
I have the bore size measurements if you care. I just have to find them.
The pics of the block and crank are in my sig in the Classifieds post.
linky.------------------> https://honda-tech.com/zerothread?id=1227409
JDM Lyfestyle
May 4, 2009 08:30 PM
Pandahatch
28
Feb 27, 2006 08:08 PM
Pandahatch
Feb 26, 2006 10:08 AM
Nextelbuddy
Jun 23, 2003 02:23 PM
