how much...
Old May 1, 2005 | 06:08 PM
digital sol's Avatar
Default how much...
how much oil does it take to fill up a 99 jdm itr motor?
i did the search and all i found was ton's of write-ups on different oils and all that stuff, just need to know how much it hold's without over-filling
Old May 1, 2005 | 06:09 PM
Chris93Si's Avatar
Default Re: how much... (digital sol)
I'm drawing a blank but I think 4.2 qt. (USDM & JDM)
Old May 1, 2005 | 06:22 PM
Stein's Avatar
Default Re: how much... (Chris93Si)
4qts if you're changing the oil, 5 if flushing it, something like that I believe.
Old May 1, 2005 | 06:35 PM
nightrider's Avatar
4 and a 1/4 always worked good with me. or 4.2 as someone already mentioned.
Old May 2, 2005 | 05:05 AM
Dave_B's Avatar
I put about 4.5 qts in mine every oil change
Old May 2, 2005 | 09:44 AM
blkitr's Avatar
i've got the jdm itr motor in mine been putting in 4.5 for about the past year and a half now and everything seems to be going strong .
Old May 2, 2005 | 05:10 PM
Viper8L488's Avatar
Default Re: (blkitr)
97 JDM ITR here. When I change my oil, it takes 4.5 quarts to get it dead on. Keep in mind, that this is after being ran for about 20 minutes and at least 1 vtec engagement. If I put in 4.5 and read the dip stick right away, it will read a little high just because the oil needs to get into all the little nooks and crannies in the engine which happens after being ran. I might be over doing it, but after I drain the old oil, I always let a fresh quart pass through before putting the plug back in just to make sure all the old stuff is out.
Boosted_01 R
Aug 12, 2008 02:56 PM
ECHb18cR
Jan 27, 2006 11:11 AM
EK [30-85]
Jan 1, 2006 11:22 AM
hatchboy93
Apr 12, 2003 07:46 PM
Screamer
Oct 25, 2002 07:02 AM
