Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Good idea or return them ? Garage related
Old May 1, 2005 | 05:51 PM
Want2race's Avatar
Default Good idea or return them ? Garage related
i found these @ Target today. $19 each for a kit that has 5 lights on it. I bought 5 sets. I thought I could install them across the ceiling of my garage to give amazing workspace lighting. I could basically have a light over whatever I was working on and avoid wasting energy.
So is the idea worth it or should I just take them back?
any advice is appreciated.
Old May 1, 2005 | 05:56 PM
Tyson's Avatar
Default Re: Good idea or return them ? Garage related (Want2race)
they sell overhead florescent lamps for less than $5 at home depot, not including the bulbs. i have no idea which would be more efficient, energy wise.
Old May 1, 2005 | 06:00 PM
Want2race's Avatar
Default Re: Good idea or return them ? Garage related (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">they sell overhead florescent lamps for less than $5 at home depot, not including the bulbs. i have no idea which would be more efficient, energy wise.</TD></TR></TABLE>
I have 4 of those right now. The problem is that they dont light up the entire area as well as I thought. Maybe more would have been the answer but the way i think this new system could remove the need for droplights in a most overhead cases
Old May 2, 2005 | 06:48 AM
Shmeek's Avatar
I'd highly recommend that you look for the High Output flourescent lights at Home Depot. They are 8ft long, but give off amazing light. I've got just 4 in my garage with plenty of light. They'll run you a bit more than the $19 Target lights.
Old May 2, 2005 | 07:41 AM
mos's Avatar
mos
Default Re: Good idea or return them ? Garage related (Shmeek)
Point light sources cast dark shadows. I would avoid those unless you are using them as an add on light source right above a work bench or something. I'm thinking of hanging some white rip-stop nylon as a false ceiling to diffuse the light from my home depot 48" flourescent lights. If its good enough for pro photographer studio...
Old May 2, 2005 | 01:42 PM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shmeek &raquo;</TD></TR><TR><TD CLASS="quote">I'd highly recommend that you look for the High Output flourescent lights at Home Depot. They are 8ft long, but give off amazing light. I've got just 4 in my garage with plenty of light. They'll run you a bit more than the $19 Target lights.</TD></TR></TABLE>
i have the same setup in my garage. three eight footers. the garage is like a operating room at night, great for working on your tan too!
Old May 2, 2005 | 01:56 PM
turbohappy's Avatar
Default Re: Good idea or return them ? Garage related (R you serious)
I find that a drop light is typically necessary anyway (working under the car or in a wheelwheel, deep in the engine bay, etc.), so having crazy bright overheads isn't that big of a help.
DA_Boy_626
Nov 4, 2007 07:40 PM
sa2214
Honda S2000
16
May 7, 2007 12:32 PM
RACEPAK
Mar 12, 2006 10:00 AM
Nataku
Oct 18, 2005 07:36 PM
Kyles ej1
Feb 11, 2005 05:27 PM
