eibach rear sway with rear break conversion?
Im planning on putting on the 94 teg rear set up, and doing the whole swap, however i was wondering if i would still be able to use the Eibach rear sway bar for my car (93 EJ coupe). or if i would need to get the Teg sway bar.. and if it would even work.. or if im just **** out of luck for a rear sway bar..? thanks
You could use any swaybar, as long as you have the holes for the brackets and endlinks, and the right endlings. If you use the integra LCA's, use the integra endlinks.
mach0
Jul 13, 2007 08:14 AM
