D16Z6 IN 89 SI..VTEC WIRING HELP..
Old May 1, 2005 | 02:37 PM
SkootA's Avatar
Default D16Z6 IN 89 SI..VTEC WIRING HELP..
hey whats up..first post...i just did a sohc vtec swap into my 89 si hatch, i used my old intake manifold distributor and ecu just need help with a way of wiring up the vtec. looking for easy controller help me out and let me know what you guys have done i was thinking obd1 ecu adapter from locashracing.com since i used to have one but for now need quick fix THANX!!
Old May 1, 2005 | 02:55 PM
CRX_Control's Avatar
Default Re: D16Z6 IN 89 SI..VTEC WIRING HELP.. (SkootA)
get the conversion harness and obd1 dizzy and p28 ecu and 4wire o2 sensor and your set .
Old May 1, 2005 | 03:23 PM
doublethink's Avatar
Default Re: D16Z6 IN 89 SI..VTEC WIRING HELP.. (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">get the conversion harness and obd1 dizzy and p28 ecu and 4wire o2 sensor and your set . </TD></TR></TABLE>
Old May 1, 2005 | 03:57 PM
Servo's Avatar
Yea, so just another $500 and you're good to go.
Considering he's probably got less than $300 into the swap already, I don't think this is the solution he was looking for... especially after going to the trouble to hack up his pre-OBD dizzy.
Three basic options that I know of...
-Summit Racing RPM activated switch
-VAFC
-TurboEdit
Just remember that you need something to adjust fuel maps above your crossover point. Otherwise you're not really accomplishing anything.
Old May 1, 2005 | 04:28 PM
EJ2-Fluffy's Avatar
Default Re: D16Z6 IN 89 SI..VTEC WIRING HELP.. (Servo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Servo &raquo;</TD></TR><TR><TD CLASS="quote">
-VAFC
-TurboEdit
Just remember that you need something to adjust fuel maps above your crossover point. Otherwise you're not really accomplishing anything.</TD></TR></TABLE>
Save the cash and get the OBD-1 conversion harness, p28 ecu, 4 wire o2 sensor and the obd1 vtec dizzy. Do it the right way.
Modified by CRX-Fluffy at 10:38 AM 5/2/2005
Old May 1, 2005 | 07:21 PM
Servo's Avatar
Save the cash? The most expensive option I suggested is less than half the price of a full OBD1 conversion.
You can engage VTEC with TurboEdit and tune with nearly the accuracy of Hondata for around $50.
Old May 3, 2005 | 07:49 AM
SkootA's Avatar
my last project was a gsr swap into an 89 civic 4dr.. i had a full custom harness with ecu adapter made from locashracing.com....that set me back a few bucks because the car was a dx so they had to wire the other injectors...but since this car is an si they have an obd0-obd1 ecuadapter for 169..obd0-obd1 distributor adapter for 25...and an engine sub-harness for 65..so figure 259+tax..im not really sure what to do this time..what you guys think?
Old May 3, 2005 | 08:00 AM
Servo's Avatar
Using the harness price you mentioned...
-Harness -- $259
-Distributor -- $150
-O2 Sensor -- $50
-ECU -- $150
-Total -- $609
If you've got that kind of money to spend, the OBD1 conversion is the best route to go. However, I personally would never spend that much cash to run a $100 head.
I chose to go the TurboEdit route, but my motor is still being built (A6 bottom end is getting a full rebuild) so I can't give you specifics about this option. I do know that there are already a couple of other guys using TurboEdit for preOBD VTEC. Search here or at PGMFI.org and see what you come up with.
Old May 3, 2005 | 08:04 AM
SkootA's Avatar
yea i guess your right..but its z6 top and bottom the old motor had a broken cam so i just swapped the whole thing i just used the old intake distributor and ecu
Old May 3, 2005 | 08:05 AM
Servo's Avatar
For all practical purposes, the blocks are identical, anyway.
Old May 3, 2005 | 08:13 AM
EJ2-Fluffy's Avatar
http://www.jkobd.com
You can use your SI harness. Just plug in the OBD0-OBD1 Conversion harness from jkobd, buy the OBD1 distributor plugs (or purchase from jkobd/rywire.com), and add the VTEC wires.
That's the easiest and correct way to do it.
-Jon
Old May 3, 2005 | 08:39 AM
CRXVTEC69's Avatar
Default Re: D16Z6 IN 89 SI..VTEC WIRING HELP.. (CRX-Fluffy)
ok I did this same swap. It is NOT going to cost you $600 to convert to obd1. p/u an obd1 dizzy for $50, and get the obd-0 to obd-1 conversion harness I got mine for $95 shipped. get a 4 wire 02 sensor and the ECU (P28) and ur good to go. Trusst me do it the RIGHT way, the way the motor was MEANT to run it will save you a lot of hassle in the long run. Besides, VAFCs are like $3-400 anyways.
Old Aug 1, 2005 | 10:08 PM
julio_bOostamante's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Servo &raquo;</TD></TR><TR><TD CLASS="quote">Using the harness price you mentioned...
-Harness -- $259
-O2 Sensor -- $50
-ECU -- $150
-Total -- $609
great advice!
i was looking into something to lead me into turning to TE for a SOHC Vtec in a EF. Now that you mention it i wonder why i didnt think of it in the 1st place.
PM6 ECu = $60
PBD0 kit= $15
Turbo edit= Free
EEprom burner=$50 shipped ( willem )
Doing it yourself and saving lots of money.... priceless!
Old Aug 1, 2005 | 10:35 PM
EF9Si-T's Avatar
Default Re: D16Z6 IN 89 SI..VTEC WIRING HELP.. (julio_bOostamante)
Go with them:
http://www.rywire.com/sitodvtec.shtml
You'll be happy you did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julio_bOostamante &raquo;</TD></TR><TR><TD CLASS="quote">PBD0 kit= $15
</TD></TR></TABLE> just wondering,what is this?
Old Aug 2, 2005 | 12:00 AM
ALLMOTORCRX20's Avatar
You can also buy a pr3 or pw0 ecu. The JDM B16A used this ecu and it will plug into your harness. With this ecu all you have to wire up in the vtec and the vtec solenoid. Vtec wire goes into pin A8. It probably wont have any wire there, it will be empty so just find another harness and take the wire out and connect it to your vtec solenoid. Then connect the Vtec pressure. Connect the black wire to a good ground and the other wire, i believe its orange/blue, connect it in pin B5. I think the wire in B5 is white/yellow. Cut the wire and wire it or take the wore wire out and put another cut wire in. Do that, and you will be set to go. Vtec will kick in.
Old Aug 2, 2005 | 12:31 AM
Malgerus's Avatar
Default Re: D16Z6 IN 89 SI..VTEC WIRING HELP.. (ALLMOTORCRX20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTORCRX20 &raquo;</TD></TR><TR><TD CLASS="quote">You can also buy a pr3 or pw0 ecu. The JDM B16A used this ecu and it will plug into your harness. With this ecu all you have to wire up in the vtec and the vtec solenoid. Vtec wire goes into pin A8. It probably wont have any wire there, it will be empty so just find another harness and take the wire out and connect it to your vtec solenoid. Then connect the Vtec pressure. Connect the black wire to a good ground and the other wire, i believe its orange/blue, connect it in pin B5. I think the wire in B5 is white/yellow. Cut the wire and wire it or take the wore wire out and put another cut wire in. Do that, and you will be set to go. Vtec will kick in.</TD></TR></TABLE>
Yes, but you'll be using a DOHC VTEC ECU for a stock Sohc... never a good situation.
Old Aug 4, 2005 | 12:37 AM
Default Re: D16Z6 IN 89 SI..VTEC WIRING HELP.. (Mr. S)
There is nothing wrong with using a DOHC VTEC ecu on a SOHC. I feel more power than with a CIVIC SI (PM6) ecu.
And I also forgot to mention that you have to modify your distributor a little so it can fit. Nothing big, just use a drill and make the hole where the bolt goes at the top of the distributor a little bigger and to the right so the bolt clears because where it threads is a little higher so it doesnt clear. You will see what i mean when you put the distributor in.
NITROUSTOMMY
Jul 4, 2009 10:20 PM
highrev1987
14
Jan 29, 2006 06:01 PM
SOLtrain "tiiiteboyee"
Feb 3, 2005 12:01 PM
uno-cam
12
Jan 11, 2005 10:00 PM
whiteknightef
Jan 5, 2005 03:00 PM
