Rota SubZero's? What weight? Any problems with them breaking?
Old Feb 1, 2002 | 09:16 PM
Black R's Avatar
25 Year Member
Default Rota SubZero's? What weight? Any problems with them breaking?
I like this rh cp035 knock off design better than the slipstreams... So if they're equally as light and strong i'll get a set of 15's...
Anyone heard of them breaking?
Old Feb 1, 2002 | 09:53 PM
Cosworth's Avatar
Default Re: Rota SubZero's? What weight? Any problems with them breaking? (Black R)
I have. Also, if the SubZ's were the same weight as the SlipS's, then it means the SubZ's have more mass distributed on the outer radius of the rim. (since SubZ's have very thin spokes vs. SlipS's good sized 5-spokes) More rotating mass on the outer edge is not a good thing given the same weight... but then, with the HP that you make, it wouldn't make a much difference.
p.s. are you back yet?
Old Feb 1, 2002 | 10:17 PM
Kengs's Avatar
Default Re: Rota SubZero's? What weight? Any problems with them breaking? (Cosworth)
He's back
Old Feb 2, 2002 | 08:26 AM
Black R's Avatar
25 Year Member
Well, I enjoy a good debate so allow me to play devil's advocate:
The slipstreams aren't necessarily stronger than the subzero's... The width of the spokes may be one thing to consider, but the depth of them is another. So they may have less width but go farther in to make up for it. Also, there are twice as many spokes to make up for that.
Nobody has any substantiated evidence of these wheels breaking, cracking, or otherwise screwing up?
.....and yes, I'm BAAAAAAAACK!
[Modified by Black R, 1:42 PM 2/2/2002]
Old Feb 2, 2002 | 08:47 AM
FAST4DR's Avatar
Give it time. A lightweight cast wheel is lightweight because there is less material used to manufacture said wheel. Any wheel will break if abused, though. Given the price of the phillipine made Rota, I guess you could still bend them and replace them up to a certain extent and still come out financially better. But what do I know. I am just a forged wheel *****...!!!!
Old Feb 2, 2002 | 12:56 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Rota SubZero's? What weight? Any problems with them breaking? (FAST4DR)
Upon impact, it's a helluva lot safer to bend a forged wheel (although more expensive) than it is to break a cast wheel (which is one reason I'm not a huge lightweight cast wheel fan). I've seen the effects of a broken wheel at speed and it isn't pretty...
gawath
Jan 26, 2006 11:50 AM
I Drive A Saturn
May 31, 2004 11:02 AM
EKtypeRhaTcH
Jul 22, 2003 11:41 PM
raw01
Jun 30, 2001 04:02 AM
