What Tranny Should i get for my y8
Old May 1, 2005 | 02:03 PM
OG SHG_EM1's Avatar
Default What Tranny Should i get for my y8
well i have a choice of either buying a tranny from a d16z6 or a tranny from a 99 y8...the tranny on my car is on its way out the door so i wanna do the swap sometime in the next few weeks to a month before my car takes a huge **** on me...so should i go for the newer tranny from the y8 or the tranny from the z6 with lower miles...both trannsmissions are a complete assembly, wires/sensors and all...
EDIT:: my car is a 98 5speed ex 4dr with about 97k miles on it
Modified by 98civicdream at 6:13 PM 5/1/2005
Old May 1, 2005 | 02:12 PM
OG SHG_EM1's Avatar
Default Re: What Tranny Should i get for my y8 (98civicdream)
ttt...add some feedback too... like info on how hard this swap is...its a first time attempt at swappin out the tranny for me but my buddy that will be with me is a mechanic so im not worried about success/failure
Old May 1, 2005 | 02:19 PM
OG SHG_EM1's Avatar
and one quick quesiton im pretty sure my tranny is a hydro tranny and the s20 from the z6 is a cable, is that a problem when it comes to tranny swaps
Old May 1, 2005 | 02:36 PM
SOHCmaster's Avatar
S40
Old May 1, 2005 | 02:37 PM
SOHCmaster's Avatar
S20 and S40 will work with no issues
Old May 1, 2005 | 02:38 PM
Kyles ej1's Avatar
Default Re: (98civicdream)
the z6 tranny is a hydro. i voted for the z6 tranny because i would always take something thats cheaper and has lower miles
Old May 1, 2005 | 02:47 PM
99hatch's Avatar
Default Re: (93ejay1)
how do you know your tranny is on its way out? what is it doing that makes you think that its gonna break/already is broken?
Old May 1, 2005 | 03:30 PM
OG SHG_EM1's Avatar
well its grinding going into 3rd, its grinding downshifting into 4th, and it pops out of 3rd frequently
Old May 1, 2005 | 03:53 PM
ILLICON5000's Avatar
get a y8
Old May 1, 2005 | 04:00 PM
braypunt's Avatar
Default Re: (ILLICON5000)
is the z6 tranny the same as a y8 gearing wise?
Old May 1, 2005 | 04:04 PM
MI KENT's Avatar
^ i think so. I know that the 96-00 d-trannys use steel shifter forks as opposed to 92-95 aluminum forks.
Old May 1, 2005 | 04:09 PM
OG SHG_EM1's Avatar
the zy has a different gearing in 3rd gear by like .001 so tis absolutely no different but the z6 i found has low miles compared to the y8 witch ha 99k miles...and i was thinking of maybe getting a new lightweight flywheel to
Old May 1, 2005 | 04:10 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (MI KENT)
If you ever plan to boost get the y8.
Old May 1, 2005 | 04:57 PM
dgdarien's Avatar
Wow, Y8 trannys are only $225? I should pick myself one up for a auto to manual swap.
Old May 1, 2005 | 05:48 PM
OG SHG_EM1's Avatar
well the y8 tranny has 99k miles so its not like its brand new...they are never really that expensive...i remember totalboost i beleive was selling s20lsd trannys for like 300-350 and thats the msot expensive d-series tranny your gonna find...junkyards will get rid of a s40 or s20 for 400-700 bucks cuz they are ********...but good ol' HT is the best marketplace to go for these things
Old May 1, 2005 | 06:08 PM
Royal_C!ty's Avatar
Z6 ...
Old May 1, 2005 | 10:43 PM
OG SHG_EM1's Avatar
ttt
Old May 1, 2005 | 10:58 PM
skip.two's Avatar
stay with the Y8 transmission. has stronger shift forks.
Z6 uses aluminum shift forks
Y8 uses steel shift forks
Old May 1, 2005 | 11:05 PM
The Internet Tough Guy's Avatar
Default Re: What Tranny Should i get for my y8 (jL iLLuZiOnz 9)
what do you have in terms of motor mounts? if your still on stock mounts, that's why you're grinding / popping out of gear. your tranny might be ok still, but it's probably fucked. i'd get some inserts for $20 (better yet fill those mounts up with some window weld for free) before i replaced the entire tranny.
i was in the same situation myself several months ago. i upgraded my mounts, and the third gear grind stopped. but if yours is popping out it might be too far gone. i ended up going with a z6 tranny a few months later, because i found a good deal on one. a clean y8 tranny at a reasonable price is hard to come by.
Old May 2, 2005 | 04:38 AM
CivicEX96's Avatar
i chose y8 for the same reason that has been mentioned twice already...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">stay with the Y8 transmission. has stronger shift forks.
Y8 uses steel shift forks</TD></TR></TABLE>
best d-series tranny out there...
Old May 2, 2005 | 10:26 AM
unsungsohc's Avatar
Default Re: What Tranny Should i get for my y8 (CivicEX96)
^^^agreed also. I have owned 3 z6 trannys all broke the shift fork. i replaced the shift fork on one of them and it broke withine 5,000 miles so Y8 all the way.
Old May 2, 2005 | 12:17 PM
OG SHG_EM1's Avatar
well the y8 is gone, i was thinking of maybe swapping out the shift forks from my y8 to the s20 because the s20 has 45k miles on it
Old May 2, 2005 | 12:44 PM
that doesn't work .. they're two very different designs. if it did everybody would have told you to do that already.
Old May 2, 2005 | 12:46 PM
Nova_Dust's Avatar
Default Re: What Tranny Should i get for my y8 (The Internet Tough Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy &raquo;</TD></TR><TR><TD CLASS="quote">what do you have in terms of motor mounts? if your still on stock mounts, that's why you're grinding / popping out of gear. your tranny might be ok still, but it's probably fucked. i'd get some inserts for $20 (better yet fill those mounts up with some window weld for free) before i replaced the entire tranny.
i was in the same situation myself several months ago. i upgraded my mounts, and the third gear grind stopped. but if yours is popping out it might be too far gone. i ended up going with a z6 tranny a few months later, because i found a good deal on one. a clean y8 tranny at a reasonable price is hard to come by. </TD></TR></TABLE>
Mine is a Y7 (I do plan on going with Y8 in the future) and I have grinded 2nd gear (going from 1st) on a turn, because I believe the mounts were too soft. Last weekend, I changed the engine mounts to Hasport 88A (extreme race) engine mounts and shifting has been beautiful. Even the common D16 reverse gear grind is gone - meaning shifting into reverse is way easier now because I could never shift it in completely at one shot, it is always 2 or 3 tries.
Old May 2, 2005 | 02:11 PM
Default Re: What Tranny Should i get for my y8 (Nova_Dust)
yep
everyone thinks for some reason that when the gears start grinding it's the syncros. honda syncros are bad ***, but the engine mounts are far from it.
