NGK spark plug wires?
Old Feb 1, 2002 | 08:43 PM
KF_S2000's Avatar
Default NGK spark plug wires?
I was told that NGK also makes some good quality spark plug wires. Is there any benefit to running the NGK wire set compared to stock wires? (all ignition system is stock and I'm not FI). Thanks for any info/opinions.
Old Feb 1, 2002 | 08:47 PM
type r 01-1063's Avatar
Default Re: NGK spark plug wires? (kf_Type-R)
ngk's are stock
Old Feb 1, 2002 | 09:00 PM
Warren's Avatar
Wrong-Way Wang
Funny thing about plug wires. I had some magnecors, and they fell apart @ the dist. cap side as I pulled them for the last time. The stock ones fit really well, and sgt dynoed the stockers to be the best, with NGK behind, and a few others behind NGK. We're only talking 1-3 hp difference, but I didn't like the way the magnecors fit anyways.
Warren, who will not run other wires unless someone pays him
Old Feb 2, 2002 | 01:56 PM
KF_S2000's Avatar
Default Re: NGK spark plug wires? (Warren)
Excellent. Thanks for the replies guys.
Old Feb 2, 2002 | 02:02 PM
bus stop's Avatar
How do I know when I need to change the spark plug wires??
If it's for spark plug.....I usually look at their conditions before changing them.....but what about the plug wires ??
Old Feb 2, 2002 | 02:06 PM
Rory Breaker's Avatar
Integras come stock with Sumitomo wires, not NGK. The plugs are NGK. You can check the wires with an Ohm meter. Positive in one end, neg on the other...I forget the proper specs off the top of my head.
NGK wires are great. Theres no need to replace your stock wires unless theyre worn out or maybe if youve made some other big ignition upgrades.
I upgraded to NGK wires when mine were toast, I noticed the car seemed to run a bit smoother.
Old Feb 2, 2002 | 02:13 PM
KF_S2000's Avatar
Default Re: NGK spark plug wires? (WhosITR)
This may seem obvious, but the first step is to visually inspect the terminals, make sure they're not bent or damaged. Check for corrosion, clean it if you find any. And then, like someone here already mentioned, you measure the resistance of the wire from one end to the other, should be about 25k ohms. If you're higher than that, time to replace the wire. And don't bend your wires at sharp angles, I've heard this can break the wire inside. That's about it though! Hope this helped.
Old Feb 2, 2002 | 02:36 PM
Kengs's Avatar
Default Re: NGK spark plug wires? (type r 01-1063)
ngk's are stock
NGK Power Cables are not stock
Old Feb 2, 2002 | 06:08 PM
bus stop's Avatar
Default Re: NGK spark plug wires? (kengs)
Thanks guys
16v
Jan 24, 2008 11:49 AM
piggydog
Nov 12, 2005 05:05 PM
Kaneo
Jun 24, 2004 02:03 PM
BoBo Racing
Feb 16, 2003 03:29 PM
CM-R
May 16, 2002 01:17 PM
