Park light repalcement???
if your talking about your side bulbs (turn signals) .. all you need to do is pull back on the fender lining and you can change it from there.. just reach in and twist and remove and replace.
open the hood , look at the lite set up there is a screw at the top remove screw slide lite assembly toward frt oc car assembly slides into 2 plastic clips sometimes they get stuck use a small screwdriver and pry gently very gently it will come out
