-Idle control via the throttle cable?
Old May 1, 2005 | 08:29 AM
Arsenal's Avatar
Default -Idle control via the throttle cable?
Well my idel has been dipping lower and lower ove time. Last night I took off the IACV on the back of the manifold and gave it a good clean out. Well put it back on and seems to be idleing alot lower now.
So for temporary I adjusted the throttle cable so it is at about 800-1000rpm now. The cable is not to tight, I only tightened it about 1 turn.
Just want to knwo if this is okay to do, and does the IACV control anything other of the engine than the idle? I knwo they are expensive to replace.
Thanks in advance
Old May 1, 2005 | 08:43 AM
EKB18BPR3's Avatar
Default Re: -Idle control via the throttle cable? (Arsenal)
ur not suppose to change the idle via throttle cable. do you have a cel?
Old May 1, 2005 | 09:42 AM
Arsenal's Avatar
Default Re: -Idle control via the throttle cable? (98B00STED)
No CEL is showing.
cdmef
Jul 3, 2011 06:03 AM
asocallocal
Sep 23, 2010 06:20 PM
Hackura
Mar 12, 2009 03:17 PM
integra99blue
Jul 16, 2001 07:56 PM
