shaking at 100kmh and while breaking
Old May 1, 2005 | 07:56 AM
Jer'rome's Avatar
Default shaking at 100kmh and while breaking
My 90 db1 is shaking when i do i 100 and gets violent at times while breaking
last week i changed uppercontrol arms, got an alignment and balanced my tires, the car drives smooth as hell other wise.. i do however have a whining axel on the passenger side, it doesnt click but it makes a stress cry while im breaking..
Old May 1, 2005 | 07:57 AM
Jer'rome's Avatar
Default Re: shaking at 100kmh and while breaking (low'N'slo)
what do you guys think
Old May 1, 2005 | 08:06 AM
keeganhartman's Avatar
I'm just throwing this out there because my 89 does sorta the same thing but it could be warped rotors or break pads ?
Old May 1, 2005 | 10:02 AM
shhh151's Avatar
Default Re: shaking at 100kmh and while breaking (keeganhartman)
had that same problem, changed the rotors and pads, problem went away
Old May 1, 2005 | 10:24 AM
Jer'rome's Avatar
Default Re: shaking at 100kmh and while breaking (GSR515)
but it when im doin 100 im not breaking, im cruising
Old May 1, 2005 | 10:26 AM
Evanmb44's Avatar
if the steering wheel is shaking, it could just be that the tires werent balanced correctly. have them checked to make sure. if it does it while braking, i would replace your rotors and pads. just try that out, and if it doesnt cure the problem, you have ruled a couple things out.
zseeanz
Mar 24, 2004 02:41 PM
tommymoose
Mar 20, 2004 07:12 PM
nikolai.
Nov 23, 2003 05:28 PM
Diablo Tejano
13
Jan 26, 2003 07:09 AM
1337 Si
Nov 25, 2002 05:51 AM
