adjusting lcon traction bars?
Old May 1, 2005 | 12:53 AM
Wraith's Avatar
Default adjusting lcon traction bars?
I was wondering how to adjust toe on the lcon traction bars, or if its even possible to adjust toe? I haven't picked up my traction bar yet so I am not sure.
Thanks in advance
Old May 1, 2005 | 04:44 PM
Wraith's Avatar
Default Re: adjusting lcon traction bars? (Wraith)
anyone?
Old May 1, 2005 | 04:54 PM
drdisco69's Avatar
Toe is adjusted on the steering rack, not the radius rods. The radius rods control caster.
Old May 1, 2005 | 07:43 PM
Wraith's Avatar
Default Re: adjusting lcon traction bars? (drdisco69)
thanks for the clear up, for some reason i thought the toe was adjusted through those raidius rods but i knew it was adjusted on the tie rods. on me
Old May 1, 2005 | 07:51 PM
TIRENECK's Avatar
do the tie rods come already set to some sort of specs? alignment is always recommended after this right?
Old May 1, 2005 | 07:59 PM
BlueShadow's Avatar
Default Re: adjusting lcon traction bars? (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK &raquo;</TD></TR><TR><TD CLASS="quote">do the tie rods come already set to some sort of specs? alignment is always recommended after this right?</TD></TR></TABLE>
When you intall aftermarket crossmembers like Lcon or Full-Race you dont touch the tierods, just the radius rods. One way to eyeball adjust the radius rod is to lenghten/shorten it until the fender gap in front of the tire and in the read of the tire is about even. To give you an example: if the tire is too far forward (radius rod too short) then the inner tire will rub the inner fender in the front. Eyeballing the radius rod length should work until the car can be taken to an alignment shop.
Old May 1, 2005 | 08:34 PM
Gant's Avatar
you get a alignment BEFORE you install traction bars
Old May 1, 2005 | 08:53 PM
BlueShadow's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">you get a alignment BEFORE you install traction bars</TD></TR></TABLE>
What about afterwards?
I dont understand what you are trying to say. Maybe you should elaborate a little bit. Why would you want to get an alignment BEFORE a traction bar install? You'll end up doing it afterwards anyways, because you're not going to be able to manually get the radius rod to the correct spec. So why do one before and after an install?
Old May 1, 2005 | 08:59 PM
Gant's Avatar
i was told by l-con when i was gonna order mine prior to install perform a alignment
Old May 2, 2005 | 04:41 AM
drdisco69's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">i was told by l-con when i was gonna order mine prior to install perform a alignment</TD></TR></TABLE>
I don't really understand why they would say that. The radius rods on the L-Con bars are adjustable, right? So the whole point is that you can adjust your caster. You're going to do an alignment afterwards then, why would you do it before? Everyone is confused....
Old May 2, 2005 | 06:54 AM
senpai's Avatar
Default Re: (drdisco69)
radius rods controls caster? hmmm, no wonder my car handles like **** I adjusted them wrong probably
Suzukii
Feb 28, 2008 05:46 PM
JBirch_97Prelude
Apr 11, 2007 05:55 PM
PA Geesir
Apr 21, 2004 06:47 AM
