How much do i over bore too get 84mm
Your LS Block is 81mm from the factory.
.020 over is 81.5mm
.040 over is 82mm
.060 over is 82.5mm
.080 over is 83mm
You will be lucky to get much over .040 on stock sleeves. To accomplish 84mm bore you need to have your LS block sleeved with aftermarket sleeves to accomodate the big bore. Use the search button it will help you out a lot in your quest for more block knowledge.
.020 over is 81.5mm
.040 over is 82mm
.060 over is 82.5mm
.080 over is 83mm
You can't bore a stock LS block to 84mm-you have to have it sleeved first. 84mm = 3.307"--stock bore is 81mm = 3.189.
3.307-3.189 = 0.118". 118 thousandths.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 »</TD></TR><TR><TD CLASS="quote">i thought the b20 block was the same as b18b only bored more?</TD></TR></TABLE>
Nope.
Nope.
THE GAME IS THICK
19
Sep 22, 2004 08:37 PM
Boostless97Lude
Nov 20, 2002 07:19 PM
