Neptuned H22...397whp/304ftlb @ 11psi....
Old Apr 30, 2005 | 05:56 PM
Bulldogg83's Avatar
Default Neptuned H22...397whp/304ftlb @ 11psi....
This past week another DFW Local (John_D) was satifisfied with Neptune. With Tony1 behind the tune, the car cranked out 397whp/304ftlb of torque at only 11psi. They stopped at 11psi because his ignition needs to be upgraded extremely bad. John said that he should be upgrading soon and then will be having Tony do the real tune to see what that little H22 can do.
Quick rundown of the setup:
H22 Block:
-89mm with Golden Eagle Sleeves
-89mm Rollerwave pistons 9.5:1
-Manley/Full Race Rods
-ARP Head Studs
Turbo Setup:
-Precision SC61 T4 (PT61)
-SST
-3"DP
-Tial 44mm Wastegate
-Tial bov
Fuel and Ignition:
-Walbro 255 HP
-Neptune
-1000cc precision injectors
Drivetrain:
-Stock Tranny- for now
-ACT 6puck with extreme PP
-ACT streetlight flywheel
Pics:
Also check out this link-->
https://honda-tech.com/zero...39273
Old Apr 30, 2005 | 06:00 PM
jnet's Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (Bulldogg83)
Looks good, pump gas or race?
Old Apr 30, 2005 | 06:19 PM
DFW's Avatar
DFW
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (jnet)
87 octane cuz he couldnt offerd 93 Octane....
jk jk it was on 93 Octane
Old Apr 30, 2005 | 06:23 PM
HRTuning's Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (DFW)
Great stuff guys...
Old Apr 30, 2005 | 06:36 PM
SpdFrk's Avatar
Thats awesome for 11psi
Old Apr 30, 2005 | 07:03 PM
prelittlelude's Avatar
still damn good, still curious about ignition at the top in full boost, funny how everyone ignores the posts they don't want to answer... neway sick nubers !
Old Apr 30, 2005 | 08:17 PM
xenocron's Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (prelittlelude)
Good stuff
Old Apr 30, 2005 | 08:56 PM
Pikachu's Avatar
Damn good stuff with Neptune.
Old Apr 30, 2005 | 08:57 PM
Rod.'s Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (xenocron)
good numbers at 11psi
Old Apr 30, 2005 | 09:28 PM
kid-crx's Avatar
nice and bump for one crazy *** manifold
Old Apr 30, 2005 | 09:42 PM
97hb's Avatar
Good stuff man I saw his car at the friday meet(couple weeks ago) and it sounded so mean taking off. Sick, sick, sick
Old Apr 30, 2005 | 10:47 PM
civicStyle's Avatar
nice car good numbers
Old May 1, 2005 | 12:02 AM
john d
Guest
Posts: n/a
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (civicStyle)
thanks for the nice comments everyone
like to give some thanks to some ppl: my g/f, bulldogg83, direp927, tony1, larry/josh at endyn for the bottom end, vp for the fab work, dfw, Tinker219, nevin, b18b, all the people that post in forced induction, and whoever else i forgot
look for some new #'s and vids soon
Modified by john d at 4:49 PM 5/1/2005
Old May 1, 2005 | 12:12 AM
budget's Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (john d)
good #'s man
Old May 1, 2005 | 01:02 AM
FastEK9's Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (ratboy)
Tony what gang sign is that? Nice numbers for such low boost. so it isnt "impossible"
Old May 1, 2005 | 01:08 AM
illi Adik's Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (FastEK9)
Ignition breaking up @ 397whp?
Old May 1, 2005 | 01:39 AM
D-tuned's Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (Jackson4Door)
sick numbers for low boost
Old May 1, 2005 | 03:20 AM
H.A.R.T B18C1EG6's Avatar
Default Re: Neptuned H22...397whp/304ftlb @ 11psi.... (2000civicsi)
Old May 1, 2005 | 04:19 AM
thermal's Avatar
sikkk!
Old May 1, 2005 | 05:18 AM
EATIN UP UR BSERIES's Avatar
good numbers!
Old May 1, 2005 | 06:55 AM
Pikachu's Avatar
Did you use Neptune with a P13 or a P28 or other ecu? I heard it works with a P13 but with limited support. I'm leaning toward Neptune for my setup.
Old May 1, 2005 | 08:58 AM
john d
Guest
Posts: n/a
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Did you use Neptune with a P13 or a P28 or other ecu? I heard it works with a P13 but with limited support. I'm leaning toward Neptune for my setup. </TD></TR></TABLE>
p72
Old May 1, 2005 | 09:02 AM
Pikachu's Avatar
Will a P28 work just as well?
Old May 1, 2005 | 09:04 AM
11psiTurboSI's Avatar
Default Re: (john d)
Nice #'s
Old May 1, 2005 | 09:12 AM
john d
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Will a P28 work just as well? </TD></TR></TABLE>
looks like you already got aem ems from your sig...?? or did this change your mind
but to answer your question, yes
