Difference in TB between B18B and B16B?
Old Apr 30, 2005 | 05:51 PM
xEnderx's Avatar
Default Difference in TB between B18B and B16B?
I was measuring the TB size and comparing the insides earlier.....unless I was REALLY off on my measurements they have the same size TB....only internal difference I could see was that the B18B TB had 2 idle air passages and teh B16B only has 1. I did not have a metric measuring tape or internal micrometer though....had to use a crappy American Standard tape.
Old Apr 30, 2005 | 07:27 PM
PyroProblem's Avatar
Default Re: Difference in TB between B18B and B16B? (xEnderx)
Hmmm. Interesting. Mine came w/o a TB so I dont know either...
Arent ITR and CTR throttle bodies the same?
Old Apr 30, 2005 | 09:21 PM
xEnderx's Avatar
Default Re: Difference in TB between B18B and B16B? (PyroProblem)
I dunno......I don't have an ITR TB to measure. I'd say its an even bet that they are.
Old May 1, 2005 | 03:48 AM
StorminMatt's Avatar
As far as I know, the B18B uses a 60mm throttle body and the B16B uses a 62mm throttle body.
Old May 1, 2005 | 10:23 AM
xEnderx's Avatar
Default Re: Difference in TB between B18B and B16B? (StorminMatt)
Ah......I see. Like I said I had a crappy *** American standard measuring tape......2 mm is a small enough amount that I could easily have missed it with such an imprecise tool.
Old May 1, 2005 | 10:28 AM
2k.civic.si's Avatar
61.5mm at opening and 60mm after the plate on a b16a2 tb...measured with a digital micrometer
LS97Civic
Apr 17, 2012 08:25 AM
chineseflyrice
Jan 23, 2007 07:06 AM
wreckedmyteg
May 11, 2004 08:24 AM
Pat
Oct 19, 2003 06:29 PM
Integra_B18B
Oct 13, 2002 12:30 PM
