toda spec b question about spec
Old Apr 30, 2005 | 05:26 PM
Grand's Avatar
Default toda spec b question about spec
i need to know what is the duration at .05" lift with the spec b cam how many degrees abdc does the intake valve close using toda bs with no cam timing factored in
Old May 1, 2005 | 06:44 AM
Grand's Avatar
bump can anybody tell me this please
Old May 1, 2005 | 11:46 AM
Pondus's Avatar
Default Re: toda spec b question about spec (LG_R32)
Specs on Toda cams are listed @ 1mm, and can be found here : http://www.allmotorhonda.com/t...s.htm
As for your other question, if they are the same as a spec C (and I believe they are), my spec sheet says the intake valve close 52.5 ABDC.
Old May 1, 2005 | 01:18 PM
Michael Delaney's Avatar
Default Re: toda spec b question about spec (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">Specs on Toda cams are listed @ 1mm, and can be found here : http://www.allmotorhonda.com/t...s.htm
As for your other question, if they are the same as a spec C (and I believe they are), my spec sheet says the intake valve close 52.5 ABDC. </TD></TR></TABLE>
the B's aren't the same as the C's for intake closing,
the Toda B intake valve ABDC closing is 50 degrees.
Old May 1, 2005 | 01:27 PM
btw we have tried to collect most of the popular cams' and stock ABDC closing specs for cylinder cranking pressure calculations over on our website in this thread:
http://www.team-integra.net/fo...age=1
Old May 2, 2005 | 01:59 AM
Pondus's Avatar
Default Re: toda spec b question about spec (Michael Delaney)
Sweet, I am a member there as well, but have not been to active there lately.
JDM-Ownz
Sep 7, 2010 02:28 PM
Mashimaro
Dec 12, 2008 11:03 AM
BigAl
Nov 9, 2005 01:12 AM
TsukubaSpec
Apr 22, 2004 08:42 PM
