question for all the B18C all motor guys
hey everyone. ive been a member here for not that long, but the site came highly recommended by a few sites that i frequent. with that said: i have a few mods ( you can check them out here ~> http://joelapiana.us/modspage.htm ) and i have on my floor waiting to go out to the shop :Skunk2 Stage II cams, S2 high comp valves, S2 springs, S2 retainers, AEM fuel rail, AEM FPR and B&M pressure gauge. (also have an AEM fuel filter that is supposed to be in a 94 teg, but i plan to make it fit) also still have to throw my prolite flywheel on.
im wondering, with tuning what kinda HP should i expect? what should i do next? should i start on the bottom end? what kinda mods should i go with to get the most power possible? (im a little sad here, i got walked by an SRT-4 today, pulled from me when we both hit 3rd; 15K in the car and still get my assed whooped by a neon...)
thanks for any and all help everyone.
joe
joe
those skunk2 springs are a no no...they break....and ya you got walked on by a srt-4....with boost controller ive personally watched them run low 13's on street tires
well, i heard many things about Skunk2 products. from what ive read, in the begining they had some trouble with cams breaking and such, but from the most recent reviews of their products i have heard them to be a very reliable product.
and yes, it walked me from 3rd.
joe
joe
i ran my friends srt4 he pulled 3-4 cars on me at the top of 4th gear.
i have 202whp on a hatch too. but keep in mind he only had 3 bolts ons and lay down 260whp and 280 torque those cars can make alot of power easy.
o, i guess as i look back at it i shouldn't really worry much about that SRT4. he is boosted after all.
on the flip side to that what do you all reccomend i do next with the Teg? aside from getting it tuned? thinking maybe a BLOX or S2 intake mani? perhaps an AEBS? <~ i forget if thats the name or not, i forget the name.
thanks
joe
thanks
joe
WEIGHT! is important also...i don't feel my car is fast at all..with my fat *** integra..buy anyways??...since ur getting your valvetrain work on..why don't u completely build the head??...v/j and PnP??...im running blox 2 on stock B18c1 compression...and i think u will do better since ur a lil up there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS93B18C »</TD></TR><TR><TD CLASS="quote">o, i guess as i look back at it i shouldn't really worry much about that SRT4. he is boosted after all.
thanks
joe</TD></TR></TABLE>
Type-r Intake manifold if fine for yuor set-up. I would not reccommand Skunk2 valves. I'd reccomand Supertech, Rev, and Ferrea.
thanks
well, i have already bought the skunk2 valves lol. 330 bucks. im putting them in! but why not? wats the problem with them?
and why a type R mani as opposed to a skunk or blox or anything else aftermarket?
not that i am trying to pick a fight or don't believe you, im just trying to learn
joe
joe
. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9800 »</TD></TR><TR><TD CLASS="quote">Type-r Intake manifold if fine for yuor set-up. I would not reccommand Skunk2 valves. I'd reccomand Supertech, Rev, and Ferrea.</TD></TR></TABLE>
The type r IM will not bolt onto a gsr head. The bolt pattern is different, so I personally would go with a BLOX or AEBS IM. Also, your cam selection.....a good one, however you will need more than high compression valves to properly run these camshafts. I would suggest doing a jdm ITR piston, put a good flowing header on it(RMF/SMS/Toda) get it tuned and then go look for that SRT-4 again
*EDIT* Get rid of those boom booms you have in there, unnecesary weight =
in racing
in racing
are they really that bad? i did some research on them and i didn't get much nay-say about Skunk products. other than the fact when they first started out.
cleanrice - thanks for the comment. i plan on building my bottom end sooner or later. and when it comes to bottom end ihave no clue what i am talking about. i decided to go with building the head firsst because i actually have a leaky valve or two and its caueing an oil leak. so you're saying ITR Pistons and a better header along with a BLO IM?
my compression as of right now should be around 10.6:1 or so. what ways can i increase that without going to the block? don't get me wrong, i do plan on building the block but probably not until next season. this is my daily driver for now.
all of your help and input is greatly appreciated everyone
thanks
joe
thanks
joe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PAndADc2 »</TD></TR><TR><TD CLASS="quote">i beat an SRT 4 ..with my integra mild built...hp on my sig!@..
ya a stock one...one with a boost controller would smoke you...
as for the skunk2 springs there is multiple threads with pics of them breaking...they all pretty much broke the same way to....since your a b18c your intake manifold options are limited....but i would say try the new skunk2 pro intake manifold....and their cams are also very good...the skunk2 stg2's are pretty much the most killer street/strip cam out there....
to increase compression you can run a thinner headgasket and mill the head a little but that decreases your piston to valve clearance which could be fatal to your motor....just my 2cents
</TD></TR></TABLE>ya a stock one...one with a boost controller would smoke you...
PAndADc2
- i plan on getting more work done to the head. the shop that does my work is sending it out to someone to have all the **** putin and hes doing some toher work too. i can't rememver all the **** but he said something about like, balancing the runners? i cant remember, it had to do with making sure each something gets the right amount of air? i dunno he talks crazy sometimes...lol
joe
joe
[QUOTE=2k.civic.si]
nah he's not stock....im thinking that he can't drive tho...his excuse was that he can't get no traction well i drove one of those my self and they do peel...well i don't really mind if i beat it or wat ever...im just happy somting happend to all my hardwork on my car...WINNING IS WINNING>>>INCH OR A MILE...LOL
Itr pistons, BLOX IM, tuned and you'll be haulin ***. I personally don't like to cut the head or deck the block, but you can do that if need be. Omni did it and made a very very powerful motor, but thats Omni. Besides valves and headgasket, there isn't much you can do to raise compression, and keep in mind you will need to pull the head to put your valves in. Good luck man
if you have spent 15 gs and still no power..
Sell everything now and get a k20a R...
I have in eg put down 211.1 145 tq untuned.. motor had 7000 miles. you can spend about 7500-9000 on full swap so you also get the 6spd and lsd for that installed etc. SRT's NO PROB.
Brandeezy1
12
Jun 23, 2014 10:17 AM
ALLOUT CL55
Northern California (Sales)
Jul 13, 2006 11:24 AM
POWERINTEGRA
Aug 17, 2004 05:02 PM
