problem with 91 hatch help
Old Apr 30, 2005 | 04:30 PM
blitzrican22's Avatar
Default problem with 91 hatch help
hey i got a 91 hatch dx and i did a swap d16z6 but i was runnim it wit the same dx distribuator now i got the rite distribuator but the hook ups arent the same so i thought i had to switchs the wires so i did but the car wont turn on do i have to get an ex harness and ex ecu and switch everythin over
Old Apr 30, 2005 | 04:42 PM
kulangot's Avatar
Default Re: problem with 91 hatch help (blitzrican22)
https://honda-tech.com/zerosearch
only takes a min. to search...
Old Apr 30, 2005 | 04:50 PM
da6jdmteg's Avatar
check the two white wires on the dist. they could be crossed. done this swap plenty of times, and i still get those two wires crossed. but if the wires are correct hasport has a wiring diagram for us to look at on line. ( selling a 89 four door civic shell 100 dollars ready for drag)
Old May 5, 2005 | 11:16 AM
Default Re: problem with 91 hatch help (da6jdmteg)
wat do u mean two white wire how and where do u put them where can get a diagram for it
Old May 5, 2005 | 11:19 AM
Brownjd's Avatar
wait a minute... you mean your running the z6 with the dpfi setup? and trying to put a z6 dizzy on there now? if so you have to swap to obd-1 and mpfi
Old May 10, 2005 | 07:45 PM
Default Re: problem with 91 hatch help (Brownjd)
yeah i noe i found out how to do it now thanks e.n.wayz
98BlackExCoupe
Aug 3, 2013 03:46 PM
lazylegs15
Nov 9, 2011 03:59 AM
BrianD1990
Classic Hondas
Feb 21, 2009 07:01 PM
blitzrican22
May 5, 2005 07:00 AM
