Suspension & Brakes Theory, alignment, spring rates....
HELP..HOW DO I GET THESE OFF...TRYED EVERYTHING
Old Apr 30, 2005 | 02:34 PM
k00lt1nt's Avatar
Default HELP..HOW DO I GET THESE OFF...TRYED EVERYTHING
Ive tried everything to get these off...what else can i do..Anyone every had this happen to them..Any suggestions or what i can do to get these damn nuts off. Its the only thing holding me bacc from finishing my swap
heres the links to the pics
http://pg.photos.yahoo.com/ph/.../e21d
any help is appreciated
thanks
Old Apr 30, 2005 | 03:20 PM
ek4d00r's Avatar
Default Re: HELP..HOW DO I GET THESE OFF...TRYED EVERYTHING (k00lt1nt)
looks like you need a special key for those. it also looks like theyve been stripped.
Old Apr 30, 2005 | 04:17 PM
SkankyEJ7's Avatar
damn is that one broken
you can always try a big screw extractor, craftsman makes them, dunno how big tho
Old Apr 30, 2005 | 06:42 PM
k00lt1nt's Avatar
Default Re: HELP..HOW DO I GET THESE OFF...TRYED EVERYTHING (hondakid1)
yah..they are both striped to hell...they are also bent in so ive tried the key i have and it just swivewls around like its to small for it..
Old Apr 30, 2005 | 08:12 PM
b18ccivics's Avatar
get a drill bit the same size as your wheel stud and mark the center of the stud with it then start drilling out the stud use a smaller bit like 1/4 inch to start with and work your way up. when you get the studs drilled out take the wheel off then knock the remaining part of the studs out of the hub. then replace with new studs and lug nuts.
Old May 1, 2005 | 03:34 AM
92b16vx's Avatar
Hard to explain, but I'll try.
Use a large screwdriver and a mallet or hammer. Place edge of screwdriver on the edge tilted down and away from the direction you want them to turn, inthis case to the right, hit the rear of the screw driver upwards and try to break them (the lugs)if they turn continue along the same line till you can get them off with something else, or by hand. I had to do this to the Torx bolts in the trailing arms.
Old May 1, 2005 | 08:33 AM
Kakkoii Integra's Avatar
New User
Default Re: (92b16vx)
use a cutting wheel on a dremel or something to cut a slot in each nut, so it's like a huge screw, which a giant flat-head screwdriver could fit into. The get a flat piece of metal (the screwdriver in this case) that fits into the slot. Find a socket that fits on the other end of that metal (21mm or so?). They either come off or tear up even worse THEN you can drill them out!
Or geez, take it to a shop and have them weld a REAL nut on top of that one. Anything to avoid drilling out the whole bolt!!
Also, whatever you try, it would be a good idea to use an impact wrech. Those can get a much better grip on anything, and the pounding action convinces many stubborn nuts and bolts to come out.
Jeff
Old May 1, 2005 | 08:10 PM
k00lt1nt's Avatar
Default Re: (frostwhite92)
i was thinking that to...jess welding a bolt to it and unbotling the whole thing...i really dont want to scratch the rim any more than it already is...but those some great ideas guys...good lookin out...
Old May 2, 2005 | 10:45 AM
gabebauman's Avatar
Default Re: (k00lt1nt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k00lt1nt &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking that to...jess welding a bolt to it and unbotling the whole thing...i really dont want to scratch the rim any more than it already is...but those some great ideas guys...good lookin out... </TD></TR></TABLE>
Weld a nut to the existing lug...
Good luck fella
Old May 2, 2005 | 02:08 PM
STS_Underdog's Avatar
Snap-On also sells wheel lock removal kits. Used one up one day when a guy came in after losing the key to his locks. The knucklehead had 5 locks on each wheel! I think we spent about 2 hours getting them all off.
pinkspider
Mar 7, 2010 07:55 AM
JDM_EK4_Coupe
Nov 21, 2006 07:42 PM
yh23
Suspension & Brakes
Jun 2, 2005 10:10 PM
vtekthis
Mar 15, 2004 10:54 AM
Cro-Mag
Jan 16, 2003 09:22 PM
