My new 85mm Copper tops came today
Old Apr 30, 2005 | 02:27 PM
2.2motore's Avatar
Default My new 85mm Copper tops came today
These are for my new big block b20 set up for this year. there Ross 12.5.1 85mm pistons with ceramic coating on the top and friction reduction on the sides.
i will post some more pic of the motor when i get it back from the machine shop. for my set-up check my sig. lmk what you guys think.
i hope i did this right
Old Apr 30, 2005 | 02:38 PM
UNforgivABLE's Avatar
Default Re: My new 85mm Copper tops came today (2.2motore)
Those look pretty baller You putting a vtec head on yoru b20 block?
Just checked your sig
Looks like its gonna be a sick setup
Old Apr 30, 2005 | 02:53 PM
Hybrid ctr's Avatar
Who did the ceramic coating?
Old Apr 30, 2005 | 03:03 PM
2.2motore's Avatar
they came coated from ross. and im putting a fully built type r head the specs are in my sig. i just wondering with tuning how much power it will make.
Old Apr 30, 2005 | 03:29 PM
TRAN's Avatar
Default Re: (2.2motore)
whats the weight on the pistons???
Old Apr 30, 2005 | 03:33 PM
2.2motore's Avatar
i have to check
Old Apr 30, 2005 | 04:27 PM
UncleD's Avatar
Depending on IM/header selection and tuning, I would put you around 215-235 range. Damn...thats pretty sick man
Old Apr 30, 2005 | 04:55 PM
cubish's Avatar
Default Re: (clean rice)
i would think more power than that, tbone is making 255 with 12.5 to 1 comp and an 87mm crank. good luck on your set up
Old Apr 30, 2005 | 07:00 PM
asubennett's Avatar
Default Re: (cubish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish &raquo;</TD></TR><TR><TD CLASS="quote">i would think more power than that, tbone is making 255 with 12.5 to 1 comp and an 87mm crank. good luck on your set up </TD></TR></TABLE>
T-Bone didn't just throw parts together and make that power.
Best head $ can buy. Beautiful ITB's that flow massive air. Great header. And the most important thing. TOns of hours of trial and error. Same to say T-Bone knows his motor better than anyone knows their own motor. 255whp is not easy. Neither is 230whp.
Old Apr 30, 2005 | 08:43 PM
Innovation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2motore &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
heavy heavy
Old May 1, 2005 | 12:00 AM
2.2motore's Avatar
thanks im crossing my fingers hopeing that the set up works well.the weight of the piston is 279 grams.
Old May 1, 2005 | 05:57 AM
Innovation's Avatar
That is kinda heavy for such a short piston and small bore. Its lighter than most shelf pistons though so its not too bad
Old May 1, 2005 | 10:00 AM
cubish's Avatar
Default Re: (asubennett)
i never said it was easy. im saying it SHOULD make more power. miamidamian was making 233 with his b20vtec 12.5 to 1 comp. stock crank, dynamic auto stage 1 cams, and a smsp header. and a type r manifold. im just comparing set ups to show him its possible to make more power.
Old May 1, 2005 | 10:30 AM
asubennett's Avatar
Yep very possible. But still not as easy as people think. Remember, when people post up numbers on this site they don't tell you about all of trials and tribulations gone through to get to that number.
Old May 1, 2005 | 04:55 PM
2.2motore's Avatar
well my set up from late last year was a ls bottom end with oversized CTR pistons and a knife edged crank and the same head. with minimal tuning we managed to put down 191 to the wheels. anything from 220 and up would be nice. i hope it makes some good torque. with some good tunning i think we can put down some good numbers.
Old May 1, 2005 | 07:45 PM
Tbone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Yep very possible. But still not as easy as people think. Remember, when people post up numbers on this site they don't tell you about all of trials and tribulations gone through to get to that number. </TD></TR></TABLE>
I agree with what you said at first " But still not as easy as people think"
But then I disagree .. I have shown every aspect in detail as to what it took for me to get here.. Now all it takes the next guy to do it is to simply copy it with their own small variations..
Old May 1, 2005 | 07:59 PM
asubennett's Avatar
Default Re: (Tbone)
I think even if someone copies your motor exactly it will still make different power by 5-10whp. Unless Brad made a CNC replica of your head no one can copy that. There will be different clearences from crank to crank. Who's to say it will be tuned the same. I think a collection of parts is just a good starting point and your work has allowed us to see how different parts work well with each other or don't work well with each other.
But your set up and power would be very hard to replicate simply by using the same parts.
vpr2
Mar 10, 2010 01:42 PM
EK SQUAD 425
Sep 18, 2007 06:48 AM
toofast4u752
Sep 5, 2007 01:49 PM
EGRhatch
Jan 8, 2005 04:29 AM
B16Hatchcx
May 3, 2004 08:08 PM
