85mm B18C headgasket options
Old Apr 30, 2005 | 10:16 AM
92TypeR's Avatar
FSAE
Default 85mm B18C headgasket options
Golden Eagle (bored OEM hg) -- So far is my first choice.
Cometic -- I hear people have problems with these.
Endyn? -- I cannot find information about this piece.
Any other options?
What is "the best" out of that list? Compression will not be totally wild, 12:1, and revvs will probably see 9000 occasionally.
TIA
Marshall
Old Apr 30, 2005 | 02:20 PM
Bradstard's Avatar
Default Re: 85mm B18C headgasket options (92TypeR)
I am running an 85mm B18C5 block and also have a Cometic head gasket. I have not had any problems and the motor revs to 9800rpms. I am also running AEBS sleeves. Good luck with the build.
Old Apr 30, 2005 | 05:37 PM
92TypeR's Avatar
FSAE
Default Re: 85mm B18C headgasket options (Fat Bradstard)
Brad,
Which Cometic do you have? There are two models I believe.
Thanks, and PS Your car is teh hawtness!
Old Apr 30, 2005 | 06:17 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
<<<<>>>>>COMETIC DEALER>>>>>>>>>>> ><<<<<<<
never had a problem with them
Old May 1, 2005 | 08:56 PM
92TypeR's Avatar
FSAE
Default Re: 85mm B18C headgasket options (HOOKUPS)
Which Cometic has the reputation of blowing? I know there are two models...
Old May 1, 2005 | 08:58 PM
Big Teggie's Avatar
I hear so much about Cometic problems but I have never had one fail on me. I have used about 5-6 different gaskets in different motors.
Go Cometic, Ross at Tuners Choice has tons in stock
Old May 1, 2005 | 10:31 PM
Quitripin's Avatar
Default Re: 85mm B18C headgasket options (Big Teggie)
i got the goldeneagle one
Old May 2, 2005 | 12:14 AM
itralex's Avatar
Default Re: 85mm B18C headgasket options (Quitripin)
The MLS one is the reliable one
Old May 2, 2005 | 03:54 AM
Tbone's Avatar
I run the cometic mls without issues...
The HP one is the one I have seen alot of probs with on allmotor cars..
Old May 2, 2005 | 07:26 AM
clint g's Avatar
Default Re: 85mm B18C headgasket options (Tbone)
Cometic seems like the best choice they used it in the B-series build so that has to mean something
Old May 3, 2005 | 09:31 AM
DYNO-PRO
Default Re: 85mm B18C headgasket options (clint g)
yes we used it in the b-series shootout motor , like i said i have never had a problem with them
true
Oct 15, 2014 01:43 PM
MR.johnson
Apr 10, 2012 06:08 AM
dartonh22
Apr 27, 2008 07:31 AM
IntegraGSR(-1)
Feb 13, 2006 10:37 AM
01-0338R
Nov 8, 2001 12:26 AM
