GS-R ECU on OBDI H22A
Old Feb 1, 2002 | 04:35 PM
Greyout's Avatar
Default GS-R ECU on OBDI H22A
what are the advantages/gains? disadvantages? complications? thanks
Old Feb 1, 2002 | 04:36 PM
4bidden's Avatar
Default Re: GS-R ECU on OBDI H22A (JDM LUDE)
i cant help you much but check out importreview.com they have a dyno chart of the two comparing them on the h22
Old Feb 1, 2002 | 04:44 PM
Greyout's Avatar
Default Re: GS-R ECU on OBDI H22A (4bidden)
hmmmm me no likes
Old Feb 1, 2002 | 06:46 PM
Honda318dx's Avatar
I wouldn't go by that, that dyno isn't right.... I am going to Hopefully soon dyno my, almost stock prelude to get a baseline, and then the GSR ecu to compare..
Old Feb 1, 2002 | 08:21 PM
aklucsarits's Avatar
New User
Speaking of OBD1 GS-R ECUs... I am looking for one to buy. If anyone has one laying around for sale, please let me know via IM.
I also have an OBD1 P13 H22a ECU with the Dinan program if anyone is interested in some sort of trade too...
Andrew
Old Feb 1, 2002 | 11:58 PM
Flavour's Avatar
Default Re: GS-R ECU on OBDI H22A (aklucsarits)
whats wrong with the P13?
Old Feb 2, 2002 | 08:18 AM
3gLudeH22A's Avatar
Default Re: GS-R ECU on OBDI H22A (Backyard Special3)
Speakin of the Spoon P13 ecu.......How much is it???? I cant find any prices for it. Anybody know of any sites i should check??
Old Feb 2, 2002 | 08:48 AM
New User
Default Re: GS-R ECU on OBDI H22A (Flavour)
The problem is that the P13 is for peak and hold injectors. The Dinan P13 I have is left over from my previous car - a 1993 VTEC. But now I have a 5th gen with saturated injectors. I do not want to hack into my wiring harnesses to add the resistor pack. So I need an ECU that is designed for saturated injectors.
The GS-Rs all have saturated injectors. The GS-R P72 ECU will simplify what I want to do...
Andrew
Old Feb 2, 2002 | 11:00 AM
Flavour's Avatar
you may want to research that. at first everyone said you needed an obd1 distributor and the resistor pack. but everything i've heard lately is you don't need either. I have a P13 in my basement, just have to figure out if I want to go through the expense of a harness and reprogram. But I'm pretty sure you don't need the resistor pack...
Old Feb 2, 2002 | 12:59 PM
sloaccord's Avatar
New User
here you go guys:
look at how lean it runs. yikes! of course that can be tuned out, but this was for testing purposes- stock vs. stock. the car on a p13 runs 180 hp/150 lb/ft, but a lot less lean, and has a much happier midrange on both torque and hp.
this is the same engine on a p13. you must remember that this dyno is without some of the stuff the above dyno has- namely, the thermal exhaust, which found a good 6.5 hp.
Old Feb 2, 2002 | 03:43 PM
Flavour's Avatar
wa that on a 5th gen or a 4th?
Old Feb 2, 2002 | 08:51 PM
New User
Default Re: GS-R ECU on OBDI H22A (sloaccord)
Nice. Great info there... Keep it coming.
Flavour: I've done better than research it. I've tried it. We tried my P13 in a 5th gen with just a convertor harness about 1 1/2 years ago. Everthing was great for about 50ft down the street before we got 3 different CEL codes... This was with no other modifications to the car... The codes were 8 - CKP sensor signal , 72 - some missfire code, and another that I cannot remember.
I am convinced that mixing and matching ECUs and different injector types is a bad idea... Not just because of the CELs we go that may or may not have had to do with the injector/injector driver difference, but because of the unpredictable fuel delivery such a set up may give...
I am planning on sticking with an ECU designed to drive saturated injectors. The GS-R one seems the best option at this point. I'm glad I saw these plots because that thing is running WAY WAY WAY too lean. I'm hoping that a V-AFC will be enough to correct that problem....
Was any further tuning done on the car in the plots with the GS-R ECU to attempt to correct the lean condition?
Andrew
[Modified by aklucsarits, 1:01 AM 2/3/2002]
Old Feb 3, 2002 | 12:34 AM
sloaccord's Avatar
New User
well. . . . technically, neither. it's in my car, but the engine is a 4th gen motor.
'92 h22a1. just so you guys know, on a later dyno (but before the p72 dyno) with the p13 and with the addition of the thermal the motor now makes 180 hp 150 lb/ft. so while it looks like the gsr ecu makes more hp, it actually makes 2 less. . . .
Old Feb 3, 2002 | 06:28 AM
illusion's Avatar
not to nit pick, but there was never a 92 h22a1. that would be a usdm motor, but it was never offered in 92. maybe you mean a jdm 92 h22a.
Old Feb 3, 2002 | 09:43 AM
Flavour's Avatar
hmm, I know there's someone else who tried it and claimed no problems. Very strange. If I can find out who I'll post it up...
Oh well, either way if I do go OBD1 I'm going to reprogram the ecu (I mean, that's the only reason I can see doing the swap in the first place) so I'll make sure that compatible injectors are programmed in there. 1 or 2 hp just isnt worth losing the immobilizer. But hopefully a programmed ecu will gain more, who knows.
Old Feb 3, 2002 | 11:54 AM
sloaccord's Avatar
New User
Default Re: GS-R ECU on OBDI H22A (illusion)
blah
yes it's jdm
i added a '1' to the end for the less educated so there wouldnt be any mistake between jdm h22a and h22a4
Old Feb 4, 2002 | 10:21 AM
93H22A's Avatar
GSR Ecu + H22 (both OBD1) = Need a vtec controller to move vtec, then you are back in business, only stronger
Old Feb 4, 2002 | 10:25 AM
JG Luder's Avatar
Or just have your stock ECU re-chipped for less, and be done with it.
Old Feb 4, 2002 | 02:11 PM
apexii's Avatar
Default Re: GS-R ECU on OBDI H22A (JG Luder)
Or go hondata and be done with it all!
Old Feb 4, 2002 | 03:23 PM
sloaccord's Avatar
New User
Default Re: GS-R ECU on OBDI H22A (apexii)
gimme a month and i'll have a dyno for that too
Chubs
Mar 11, 2003 09:11 AM
SiRCal
May 3, 2002 05:51 AM
se93
Oct 19, 2001 04:51 AM
aklucsarits
Jul 27, 2001 03:53 AM
