what's needed to convert my OBD0 crx b20-vtec to OBD1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnut »</TD></TR><TR><TD CLASS="quote">I already have a P28 ecu of a 92 si.
I know i need an OBD0 to OBD1 wiring conversion.
what else?? do i need OBD1 distributor.
thanks.</TD></TR></TABLE>
You can use either an obd-1 or obd-2 distributor, which ever will bolt up to your head directly. Also, you will need a 4 wire O2 sensor.
I always think of it was, OBD1 is 4 parts away.
1. ECU
2. Conversion Harness
3. Distributor
4. 4 wire O2 sensor
(5) fuel injectors (but you need to remove the resistor box if you get obd1 injectors)
1. ECU
3. Distributor
4. 4 wire O2 sensor
check out http://www.rywire.com just purchased the obd0-1 conversion stuff
bump the things above
1.harness
2.distributer
3.distributer adapter harness
4. optional 4 wire o2 you dont need one if you are going to have the ecu chipped they can delet the o2 sensor completely
1.harness
2.distributer
(1SlowB16EF)
gives you a lot of option in engine management. ie. hondata, etc.
more questions.
so if i use an OBD1 distributor how would i modify the dist. wiring socket or plug??
and if i use a OBD1 injectors i would need to unplug my resistor box..just unplug
it - nothing else.
more questions.
it - nothing else.
LSXFEIND
Mar 12, 2009 06:09 AM
EFing8
11
Dec 15, 2002 09:08 AM
