rear springs loose from drop
Old Apr 30, 2005 | 07:44 AM
91DA's Avatar
Default rear springs loose from drop
I used H&R springs off a 2000 SI to drop my 91 DA. the spings fit, but when I put the car on a jack the rear springs get really loose. They move out of place and have enough space to go up and down. when I lower the car, the springs fit perfectly into place. is it supposed to be like that in the rear or how?
Old Apr 30, 2005 | 07:49 AM
91DA's Avatar
Default Re: rear springs loose from drop (91DA)
bump
Old Apr 30, 2005 | 08:01 AM
91DA's Avatar
Bu m p
Old Apr 30, 2005 | 08:11 AM
sooo_slow's Avatar
New User
yeah its supposed to be like that, because the springs are shorter than the stock ones...dont worry everything is fine..my coilovers do the same thing...
Old Apr 30, 2005 | 09:21 AM
Backk InTheDA's Avatar
I hate everything
You'll be fine, my buddy just put springs onto his DA, and when he put the wheels back on the ground, the spring settled, you'll be fine.
Old Apr 30, 2005 | 11:08 AM
purplegsr's Avatar
Default Re: rear springs loose from drop (iTR2The3rdGen)
Did you modify your top hats at all to take the larger diameter spring? It could be sitting on the rubber piece inside the top hat and not going fully into the top hat, which would cause it to drop out of place at full droop.
You could get some EK tophats to make up for it, but as long as the spring is going all the way into the top hats when the car is lowered down from the jack, you should be fine. You will never go to full droop when the car is on the road.
Old Apr 30, 2005 | 11:39 AM
91DA's Avatar
Default Re: rear springs loose from drop (purplegsr (Exospeed))
the tophats fit when the car is lowered. So basically, the weight of the car is compressing the spring.
randerson0248
Jun 29, 2008 02:26 PM
BlueRex1020
Feb 9, 2007 04:43 PM
GTA
Suspension & Brakes
May 22, 2006 07:49 AM
Wazup
Suspension & Brakes
Feb 6, 2006 10:46 PM
NINJASPY
Jan 16, 2004 10:46 AM
