SiR power folding mirrors?
I was wondering if this means that in addition to being powered, that you press a button and they will electronicly fold inwards? Or are they simply power mirrors, that you can manually (with your hand) fold inwards.
Thanks.
Thanks.
As long as I dont have to take out any more Metal Gears
yes they fold in with the push of a button. However, u will need the JDM switch, and the JDM relay as well. Not easy parts to find though
You will need the mirrors as well as the switch itself as a minimum. There are instructions out there to wire up the folding part using a DPDT (Double Pull Double Throw) relay. (Standard 30a relay is a SPDT). The power mirror part should work the same.
vti444
11
Apr 30, 2009 11:35 PM
fujiwara takumi
May 6, 2003 10:49 AM
