Two Wire or Three Wire for Thermal Arc 185TSW?
Old Apr 29, 2005 | 06:44 PM
Pikachu's Avatar
Default Two Wire or Three Wire for Thermal Arc 185TSW?
Whcih wire should I go with? I figured I need 8 gauge wire for the welder already. I'm going to have this wired up tomorrow. Thanks guys.
Old Apr 30, 2005 | 10:03 AM
racerxadam's Avatar
Default Re: Two Wire or Three Wire for Thermal Arc 185TSW? (Pikachu)
for that welder you are looking at 30-40 amps input when welding close to the limit of the machine. You should be looking at a 6 gauge wire to handle that safely. As far as two or three wires, it should be three. For single phase 220 you have one ground and two hots.
Old Apr 30, 2005 | 10:43 AM
98AccordEX's Avatar
Default Re: Two Wire or Three Wire for Thermal Arc 185TSW? (racerxadam)
i have 8/3 for my Syncro180. i asked the electrician that did the wiring on my house and he said 8/3 would be plenty. i was making an "extension cord" and he said that if i made it 30 feet then 8/3 would be fine. but if i made it about 50 feet then i should go to 6/3 or i might get some drop in current but i probably wouldnt. so i made it 30 feet and got 8/3 and its been great
Old Apr 30, 2005 | 10:48 AM
5thgencivic's Avatar
I went with 6-3. Make sure you get the copper and not the triplex(aluminum), even though if you are wiring it up I'm sure you already know about it.
Old Apr 30, 2005 | 09:38 PM
racerxadam's Avatar
Default Re: Two Wire or Three Wire for Thermal Arc 185TSW? (98AccordEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98AccordEX &raquo;</TD></TR><TR><TD CLASS="quote">i have 8/3 for my Syncro180. i asked the electrician that did the wiring on my house and he said 8/3 would be plenty. i was making an "extension cord" and he said that if i made it 30 feet then 8/3 would be fine. but if i made it about 50 feet then i should go to 6/3 or i might get some drop in current but i probably wouldnt. so i made it 30 feet and got 8/3 and its been great</TD></TR></TABLE>
what size breaker is that on? The idea is that you want to breaker to flip off before the wire gets too hot to catch fire. I know that you are probably ok with 8/3 but I don't want my house/shop burning up over something like 50 dollars difference in wiring.
Tippyman
Audio / Security / Video
23
Nov 28, 2008 03:10 PM
San-Wan
Sep 30, 2008 07:28 AM
rsdriver17
Mar 10, 2007 09:59 PM
hkboy87
Mid-Atlantic (Sales)
Jul 30, 2006 07:49 PM
mrlegoman
Feb 3, 2003 04:15 PM
