b20 block with b18b head?
ok guys im slowly starting my all motor project here, i have an ls in the car right now, but im thinking of swapping my ls block for a b20 block, can i still use my ls head and what will me stock power output look like so i have a base to go off of? i was thinking i should retain my stock hp rating of 142 but torque would be more like the b20 at 130-135. does this sound about right? and what would my compression ratio look like?
yes it will work and the LS IM is better. With the LS head you will gain a lil compression since you are putting a 81mm chamber head on a 84mm bore block.
Is your head a P75 or PR4?
