2.0 base map
i need a base map in uber or a tuned map for a 85mm bore 89mm crank 440 injecotrs aebs intake mani 74mm throttle toda spec d cams 12:5:1 compresssion on 94 pump gas got it running but just cant even drive it do the dyno it cuts inand out and is running rich at like 11-12 on my plx any help would be greatly appreciated thanks alot hope to hear from u guys and get this thing on the road
vince
vince
Don't know where to get it or how much. Someone on Honda-Tech needed a base map for Uberdata, and all I had was Hondata. He said that he had the software to convert my Hondata map to Uberdata. A good place to search is here:
http://www.pgmfi.org/twiki/bin...bHome
hey sry to ask about something different then the thread but, i just got hondata installed on my p28 w/ a basemap for my motor. You think it'll be alright to drive around normally w/ it so i can break the motor in or should i just take it to the tuner first?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by konrad »</TD></TR><TR><TD CLASS="quote">hey sry to ask about something different then the thread but, i just got hondata installed on my p28 w/ a basemap for my motor. You think it'll be alright to drive around normally w/ it so i can break the motor in or should i just take it to the tuner first? </TD></TR></TABLE>
Tune First!
Tune First!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">I have Hondata maps, but you need the software to convert them to Uberdata.</TD></TR></TABLE>
Hi, I need a basemap as well and i have hondata think you get share one with me ?? I am interested in the ignition maps. Fuel maps i can figure out as i have a plx and data loging.
b19coupe i sent you pm.
my setup is
84.5 mm bore gsr bottom end,
stock crank,
b16a first gen head full p&p,
stage 2 wicked cams,
hookups header,
13:1 cr,
440 cc rc peak and hold injectors,
obd0 to obd1 conversion.
255 lph walbro
my setup is
stock crank,
hookups header,
13:1 cr,
255 lph walbro
