get Z motor Question
Old Apr 29, 2005 | 04:18 PM
sikciv666's Avatar
Default get Z motor Question
my boy just picked up an 89si and this came under hood.....im sure its a ZC but from what year?.....the code is like D16ab1 or some ****...hook a brother up
Old Apr 29, 2005 | 04:32 PM
skud_dusty's Avatar
Default Re: get Z motor Question (sikciv666)
It's a Rover engine...
Some Rover's in Europe came with Honda engines. Some had sohc ZC's, some had dohc ZC's.
*edit*
Here's a guy that has a Rover 216 w/ an A6 in it
http://www.cardomain.com/memberpage/784290
Old Apr 29, 2005 | 04:50 PM
sikciv666's Avatar
Default Re: get Z motor Question (beaterex)
good **** man, can i get a little more insight on this (Rover) motor?
thanx guys
Old Apr 29, 2005 | 05:26 PM
sikciv666's Avatar
cmon kids
Old Apr 29, 2005 | 07:07 PM
sikciv666's Avatar
up, cmon
Old Apr 29, 2005 | 07:08 PM
gutterslide's Avatar
it's a D16A8 or A9. it's basically a Euro ZC. European Hondas came with the same engine (D16A8/A9), but with the standard ZC-style valve cover. the valve cover on the engine in your pic means it came from a Rover. There are no real differences between the D16A8 and the ZC. The D16A9, however, has lower compression because it didn't have a catalytic converter, and didn't need the extra compression to make the same amount of hp as the D16A8, with a cat.
D16A8 9.5:1 (catalytic converter)
D16A9 9.1:1(no catalytic converter)
came in European Civics and Concertos? from around 88-91, and Rover 216/416 GTI from around 89-96-ish
i have a Rover D16A8 in a Civic wagon, and i have no complaints.
For all intents and purposes, it is a ZC. Same hp, same compression, same everything. well, almost.. there are couple millimeters difference in some of the internal parts, but i can't remember which. seems like the thickness of the rods, maybe. One good thing about a D16A8 from a Rover is that they put them in cars up until 1995/6, which means you may get a slightly newer engine than if you got a ZC. someone on the net stated that their D16A8 (Rover cover) came out of a JDM Isuzu, but there has been no proof that i know of.
oh, and the year should be stamped on the block, above the exhaust manifold.
2 numbers, one on either side of the dipstick, like... 8|9
Modified by gutterslide at 4:35 AM 4/30/2005
Old Apr 29, 2005 | 07:28 PM
Default Re: get Z motor Question (gutterslide)
it should look like this. i didn't go down to check mine, but i'm pretty sure.
and here are some Rovers that came with these engines.
Old Apr 29, 2005 | 10:50 PM
UltimX's Avatar
Are the head lights on the rover clear? or is it just the picture that doesn't show the ruffels in the lenses?
Old Apr 30, 2005 | 02:27 AM
Change's Avatar
Default Re: get Z motor Question (UltimX)
i know a guy with this engine in his crx si and hes pretty happy with it. nothing wrong with it at all.
Old Apr 30, 2005 | 08:03 AM
Import_lifestyle's Avatar
the rover has some what of a resemblence to a 92 teg....or it could be just me
Old Jun 22, 2005 | 06:47 PM
importslife's Avatar
Thats whats up!! i got one for mine to
Modified by importslife at 1:59 PM 6/23/2005
ggallinstyle
10
Dec 6, 2012 06:17 PM
Rywire
14
Aug 27, 2005 07:57 AM
slate13530
26
Sep 24, 2004 08:28 AM
91b16acrx
71
Feb 17, 2004 04:49 AM
Creepshow S60
21
Oct 18, 2003 10:42 AM
