del sol b20 mount problem
del sol with b20block gsr head 2000type r tranny the problem is the fron mounts from the b20 dont line up which mounts do I use in which places... any help greatly appreciated
Modified by tc_gts at 4:20 PM 4/29/2005
Hey i got a b20 in my del sol you need a mount from a 99 si b16a but the cast mount not the rubber bushing but you rubber bussing may be the 3 hole version you may need the two hole one for it to work
