Falken Azenis on stock ITR wheels?
Old Apr 29, 2005 | 02:28 PM
ITR198's Avatar
Default Tires
would falken azenis be a good choice to put on the stock rims
Old Apr 29, 2005 | 02:32 PM
itr1244's Avatar
Default Re: Tires (ITR198)
i never had them but they are supposed to be pretty good..
so.. yeah you can put them on stock rims.
but do some searching
Old Apr 29, 2005 | 02:35 PM
p nut's Avatar
Do some searching and read the FAQ's.
Just to answer your question--Although a wider rim is recommended, the Azenies will fit over the stock rims. People track them all the time with no problems.
Seriously, though, search next time, or you'll get eaten alive.
Old Apr 29, 2005 | 06:32 PM
Bbasso's Avatar
start learning about tires so you know what your putting on your car. A informed buyer is a smart buyer.
https://honda-tech.com/zerothread?id=624059
https://honda-tech.com/zerothread?id=665478
https://honda-tech.com/zerothread?id=298583
https://honda-tech.com/zerothread?id=160553
Old Apr 30, 2005 | 05:26 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR198 &raquo;</TD></TR><TR><TD CLASS="quote"> would falken azenis be a good choice to put on the stock rims </TD></TR></TABLE>
In case you didn't read through all the hype, the basic answer is that yes, the 205-50-15 Azenis will work just fine on stock rims, within the design parameters of the tyre. That is to say, warm weather. Be mindful, too, that as the tread blocks wear down, they will do less and less well in wet weather, being unable to channel water effectively as the tread blocks wear down.
They will still be fine in warm, dry weather for a long time after the tread blocks wear down enough not to channel water.
You will like them better on 7" wide wheels.
jawxx
Oct 1, 2009 07:44 AM
xander1100
Aug 11, 2009 08:54 PM
kalenz
Jul 1, 2005 09:49 AM
ntt
Feb 16, 2004 11:11 PM
ITRyder
Jun 30, 2002 05:39 AM
