si tranny vs. type r tranny all motor
i know that si trannys are better for boosting while type r trannys are better for all motor but i've been looking around and cant find the final drive ratio's for these to see how big of a difference they are. i already have a 2000 b16a tranny cause i was planning on going eg and boosting it but i fell in love with the ef and now im planning on going all motor in an ef so how big of a differenc would it make if i kept the b16 tranny vs the type r tranny for all motor...should i sell the b16 and pay all the extra money just to go with the type r or should i stick with the b16. by the way i have a b17 that i am going to be using for this so please give me feed back...thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom grey eg »</TD></TR><TR><TD CLASS="quote">si tranny - 4.40 final drive, no lsd
Type r - 4.70 final drive with lsd
its a no braner to me type r all the way</TD></TR></TABLE>
plus lsd... and doesnt it have dual synchros on all gears?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 »</TD></TR><TR><TD CLASS="quote">
plus lsd... and doesnt it have dual synchros on all gears?</TD></TR></TABLE>
No.
No.
Depends what Type R you're talking about.
USDM Type R, B16 hydro, and CTR all have the same ratios even final drive. 4.40
The 4.785 Type R trans is only the JDM Type R not USDM.
The JDM Type R trans has B16&GSR ratios which helps bring the over all ratio for 5th back to a normal speed
http://www.allmotorhonda.com/t...s.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo »</TD></TR><TR><TD CLASS="quote">Depends what Type R you're talking about.
http://www.allmotorhonda.com/t...s.htm</TD></TR></TABLE>
98+ JDM ITR has the 4.785 and the 4/5th gear are GSR gears.
pre98 JDM ITR is 4.4 and same as USDM ITR gearing
USDM ITR and 99-00 SI Trans are the same gearing and FD of 4.4... only difference is the LSD.
plus lsd... and doesnt it have dual synchros on all gears?</TD></TR></TABLE>no, it has a double cone syncro on second, and BTW only JDM 98spec trannys have a 4.7 final drive, the 96spec has a 4.4 like the Si. Also another thing to note is that the 98spec tranny also has the same 4th and 5th gears as a GSR due to the shortness of teh 4.7
edit: splitime beat me to is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix »</TD></TR><TR><TD CLASS="quote">edit: splitime beat me to is
I rule
</TD></TR></TABLE>I rule
