TUNING
Ok here is my setup:
OBD1 JDM D15B VTEC motor
A6 trans
A6 clutch disk
JDM D15B VTEC pressure plate
A6 flywheel
VAFC ll
custom exhaust manifold
JDM D15B VTEC intake manifold
P08 ECU
Now, I am in desperate need of tuning. The car is like sputtering while Im driving. It idles fine, but once I get going, sometimes it sputters like I am blipping the gas pedal or something then sometimes it is fine. I dont understand y it is so intermittent. I want to know if there is someone around here that can tune this motor or someone you can recommend thank H-T members
Oh! this is all in a 88' CRX Si
A6 trans
A6 clutch disk
A6 flywheel
VAFC ll
P08 ECU
had a customer with similar motor ... took alot of tuning since no other ecu will work with it because injector size is diff on these motors.
I can do an eprom for you to use, pm me
greg
greg
1992hondacivicvx
Dec 3, 2010 07:50 AM
