Some one Ghetto rigged This swap i need a little help
Old Apr 29, 2005 | 12:33 PM
Edgemingsr's Avatar
Default Some one Ghetto rigged This swap i need a little help
Hey guys i bought 91 civic DX with a 91 SI motor in it. (d16a6) The motor was pretty much shot so i bought another d16a6 to put in it. While i was dropping the old motor out i realised that everything was wired and taped and sensors were cut and spliced. it was just a mess. I bought a 91 si engine harness for the the new motor for when i put it in.
Everything pluged in ok except for one plug. on the driver side. its the part of the engine harness that plugs in to the other harness that goes to the ECU. those two plugs will not plug in to eachother. So now what? Do i absolutely have to get the harness from the engine bay to the ECU or is there a simpler cheaper way around this. Thanks guys
Old Apr 29, 2005 | 12:43 PM
92civicfreak's Avatar
i would say just get the connector to the new harness that u got, & rewire the wires into the CORRECT holes
Old Apr 29, 2005 | 01:00 PM
dr_latino999's Avatar
Default Re: Some one Ghetto rigged This swap i need a little help (Edgemingsr)
Good way of doing it, but what you needed was a NEW DX engine harness. You plug that into the main harness and from there you connect everything except distributor and injector wiring. From that point redo the MPFI wiring into the main harness and call it a day.
Old Apr 29, 2005 | 01:58 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Some one Ghetto rigged This swap i need a little help (dr_latino999)
YOU ARE FUCKED
well not really.
I had a **** harness and its been ******* me for ages.
It'll take some work but you can get it done and running fine.
Dr. Latino is right just get a DX harness start over again, thats what i'm doing and i'm nearly running.
Old Apr 29, 2005 | 10:13 PM
civbeater90's Avatar
Default Re: Some one Ghetto rigged This swap i need a little help (Ace$nyper)
not to be a ***** but buy a helms manual.you will not regret it.every single wire layed out for you
DOHCintegra91
Sep 24, 2006 08:29 AM
ef-hatchcrap
Feb 3, 2006 03:22 PM
Keith P
Jun 12, 2005 04:33 PM
Sean_b
Jun 23, 2004 01:19 PM
elmalouno
Apr 26, 2004 02:35 PM
