Rear Brake Conversion:88 Crx Si to 93 DA Brake - quick question
Old Apr 29, 2005 | 10:48 AM
SiR Inspired ED7's Avatar
Default Rear Brake Conversion:88 Crx Si to 93 DA Brake - quick question
Can i use this line for the conversion or do i have to use the integra one?
Old Apr 29, 2005 | 10:51 AM
dr_latino999's Avatar
Default Re: Rear Brake Conversion:88 Crx Si to 93 DA Brake - quick question (88 Crx Si)
If that is the E-Brake line you need to use the one from another SI I believe. The Integra cable is the right length though for the hatch and the sedan.
Old Apr 29, 2005 | 10:53 AM
Default Re: Rear Brake Conversion:88 Crx Si to 93 DA Brake - quick question (dr_latino999)
so i can't use that line? my car is a 88 crx si. what line am i suppose to use?
Old Apr 29, 2005 | 10:56 AM
For a CRX you will need the Emergency Brake Cable from a CRX SI equipped with rear discs.
Chase's Avatar
90-91 crx si line
Old Apr 29, 2005 | 10:59 AM
Default Re: Rear Brake Conversion:88 Crx Si to 93 DA Brake - quick question (b16crxkid)
ok, guys thanks alot! now i need to get a 90-91 si line
Old Apr 29, 2005 | 01:51 PM
Dyn0speed's Avatar
i use all integra parts including brake lines and ebrake cable in my 91 hf. im also using DA front knuckles and Ingalls camber kit to compensate.
Modified by Dyn0speed at 2:04 AM 4/30/2005
Old Apr 29, 2005 | 05:00 PM
Si2See's Avatar
why cant you use the integra line?
Old Apr 29, 2005 | 06:09 PM
b18cEF9's Avatar
Default Re: (Si2See)
to loooong on the rex, but works with teh hatch and sedan as noted earlier
Old Apr 29, 2005 | 06:39 PM
shawn_crx's Avatar
Default Re: (b18cEF9)
E-brake cable
I called the dealer and they said it's about $60 a piece.
Old Apr 29, 2005 | 06:54 PM
Deetz's Avatar
Crazy Honda Guy
I used new 91 Si cables on my 89 Rex with DA disk conversion, fit perfect. Getting new cables is not a bad thing.
Old Apr 30, 2005 | 10:11 AM
Dyn0speed's Avatar
Default Re: Rear Brake Conversion:88 Crx Si to 93 DA Brake - quick question (Dyn0speed)
Theres a trick to everything. try looping it somewhere
Modified by Dyn0speed at 1:53 AM 5/2/2005
Old Apr 30, 2005 | 01:21 PM
bagpipe goatee's Avatar
the hatch is longer by like 4 inches. if theres room to make a loop or something underneath, the line will fit.
Old May 5, 2005 | 11:56 AM
donuttes's Avatar
so if i had DA brakes on a 90 SI, would the DA ebrake cables be the right size to make it back there and function properly?
Old May 5, 2005 | 12:34 PM
Default Re: (donuttes)
It will function properly, you just will have to be creative with the routing to take out to extra four inches of slack.
Old May 5, 2005 | 03:15 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">I called the dealer and they said it's about $60 a piece.</TD></TR></TABLE>call Napa, the dealer will almost always be more expensive
Old May 6, 2005 | 01:56 AM
Sgt_Ox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si2See &raquo;</TD></TR><TR><TD CLASS="quote">why cant you use the integra line? </TD></TR></TABLE>
I'm using the DA e-brake lines in my CRX and I just swapped the cables around when routing it to the inside of the car. In other words the inlet for the passenger side cable has the driverside cable running through it, and vice versa. It'll tie up abotu another 2-3 inches which is perfect.
dacrxguy
Jul 24, 2009 09:58 PM
CRX 2.0V-T
Jan 8, 2007 12:17 AM
ThatsMyEG
Jan 17, 2005 01:31 PM
SoulSurfer
16
Apr 30, 2004 03:50 PM
chadmasterc
Feb 24, 2004 08:23 PM
