zenki tuner lugnuts stripped
Old Apr 29, 2005 | 09:56 AM
t0ekn3e's Avatar
Default zenki tuner lugnuts stripped
any one have any idea to get off a zenki tuner lugnut off that has stripped i cant fit a regular socket over it becuase it round on the outside.
Old Apr 29, 2005 | 10:40 AM
B2FiNiTY's Avatar
Default Re: zenki tuner lugnuts stripped (t0ekn3e)
How did you strip it?
Old Apr 29, 2005 | 10:53 AM
t0ekn3e's Avatar
i just stuck the key in and tried to remove the lug nut and the inside got fucked up i alswaies torque it down to 75lbs when i tighten them
Old Apr 29, 2005 | 12:00 PM
fillup's Avatar
get a socket thats smaller than the lug, use a hammer and hammer it on the lug until its tight. use your ratchet to take off the socket and lug at the same time. use a socket you dont mind throwing away though.
Old Apr 29, 2005 | 02:01 PM
t0ekn3e's Avatar
got it thanks alot every one
Old Apr 30, 2005 | 03:51 PM
FormulaGSR's Avatar
Default Re: (t0ekn3e)
what the hell is a tuner lugnut
Do they make Tuner valve stems too
Old Apr 30, 2005 | 03:58 PM
fillup's Avatar
The seating is shaped differently than oem lugs.
check the sticky: https://honda-tech.com/zerothread?id=1188922
Old May 1, 2005 | 12:56 AM
DxBurnoutKing's Avatar
Default Re: (FormulaGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">what the hell is a tuner lugnut
Do they make Tuner valve stems too </TD></TR></TABLE>
some aftermarket wheels have tiny little holes where fat ol regular lugs wont fit... so we gotta use "Tuner Lugs" to mount the wheel.
Old May 1, 2005 | 07:56 AM
FormulaGSR's Avatar
Default Re: (DxBurnoutKing)
wow those arent plain ole' tuner lugnuts, those are "super tuner lugnuts"
Old May 1, 2005 | 09:26 PM
Thrillhouse's Avatar
I am having the same problem, Im going to try roundouts made by craftsman Ill let you know if it works
Old May 2, 2005 | 05:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">wow those arent plain ole' tuner lugnuts, those are "super tuner lugnuts"</TD></TR></TABLE>
its mad jdm.....y0
Old May 3, 2005 | 07:24 PM
Rtistik.'s Avatar
haha you havent had many aftermarket wheels huh...
Old May 4, 2005 | 06:44 AM
GUILOTINE's Avatar
Kill Gil
you need acorn seat lug nuts for after market wheels, you uuse ball seat lugs for OEM wheels
Old May 18, 2005 | 07:17 PM
darrinbrewer's Avatar
Default Re: (GUILOTINE)
those look like my gorilla lugs i got from jcw last year..never stripped, and still go off and on easy, for gorilla
laocivic
Feb 5, 2008 07:43 PM
EKshin
Jul 15, 2006 08:57 AM
Cliffjumper2
May 30, 2005 08:14 AM
jimmhatch
10
May 21, 2005 05:21 PM
S13 slide
Nov 11, 2003 01:44 PM
