Mugen Header Questions
Old Apr 29, 2005 | 09:21 AM
nickgomez's Avatar
Default Mugen Header Questions
Hello guys, some header questions:
a) Is it OK to fit a DC2 header to a B16A? Any problems?
b) Has anyone installed any of the following headers to an EF8/EF9? Do any of these fit?
- Mugen 18100-XG9R-K0S0 (DC2/DB8 96 Spec. R 4-1)
- Mugen 18100-XG9R-K3S0 (DC2/DB8 98 Spec. R 4-1)
- Mugen 18100-XG9R-K2S0 (DC2/DB8 98 Spec. R 4-2-1 Gymkhana Spec)
OR
- Mugen 18100-XGE-K0S0 (EG6/EG9 4-1)
- Mugen 18100-XG9R-K0S0 (EK9 4-1)
Any comments would be much appreciated. I'm thinking of using it for a daily driver.
Old Apr 29, 2005 | 10:49 AM
dr_latino999's Avatar
Default Re: Mugen Header Questions (nickgomez)
The only problems I see with a header designed for the B18C is that it will hang a little bit lower and it will also not be tuned for a 1593cc motor.
Old Apr 29, 2005 | 04:30 PM
nickgomez's Avatar
Default Re: Mugen Header Questions (dr_latino999)
Thanks. A friend just messaged me this:
"No, block is different, hence header holes are different sized."
True?
Pardon my ignorance.
Old Apr 29, 2005 | 04:48 PM
RF's Avatar
RF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickgomez &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. A friend just messaged me this:
True?
Pardon my ignorance.</TD></TR></TABLE>
from what i understand the holes will line up, so you will be able to bolt it up. but the b18 block is taller then the b16 block, so there may be some clearance issues if you used a b16 header with a b18 block. if you used a b18 header on a b16 you wont have any problems, it will just hang a little lower.
Old Apr 29, 2005 | 11:04 PM
Nerologic's Avatar
other then the header hanging a bit lower, the cross member must be hacked for all of the mugen 4-1's the mugen 421 clears though...
2LEM1
Mar 12, 2012 07:35 AM
THEUSED
Apr 3, 2006 09:47 PM
QuanKwan
Dec 17, 2003 05:23 PM
kidzoom206
Oct 31, 2003 01:31 AM
supergodzilla
May 16, 2001 07:50 AM
