What injectors to use!!!
Old Apr 29, 2005 | 08:33 AM
00ek9civicjay's Avatar
Default What injectors to use!!!
ok so i'm doing a D-series turbo setup and i got some DSM 390cc injectors w/ a resistor pack. i planned on using that. people tell me i can use those injectors and others say no. i'ma ask you guys cuz i'm sure ya'll know. what are some injectors i can use that just plug in play for my D-series turbo? if anyone can help me w/ that i would appreciate it. this is prolly the hardest thing i'm dealing w/ in this lil turbo project and i just need to find some good injectors that will just plug in play.
Jay
Old Apr 29, 2005 | 08:51 AM
Pioneer162's Avatar
Default Re: What injectors to use!!! (00ek9civicjay)
get some saturated RC injectors, they are plug n' play in odb1 cars... you can find them in the classifieds when your trial status is up. I think you can use the ones you have too though, I've never had a need for them though. Sorry I couldn't be more help
Old Apr 29, 2005 | 08:56 AM
ssbpturbohatch's Avatar
homemade or aftermarket turbo kit? how much psi?
Old Apr 29, 2005 | 09:14 AM
Default Re: What injectors to use!!! (ssbpturbohatch)
its a 15g greddy turbo kit for a 92-95 civic. anyways i plan to switch over to Obd1. i still need a p28 chipped and get it tuned using Hondata! i'ma run 10lbs. of boost...no more after that.
Old Apr 29, 2005 | 09:46 AM
just go with some rc 310's and you should be fine, what kind of fuel mgmt. do you have like fmu or fuel pump or anything else?
Old May 5, 2005 | 08:36 PM
dvtlegend's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00ek9civicjay &raquo;</TD></TR><TR><TD CLASS="quote">its a 15g greddy turbo kit for a 92-95 civic. anyways i plan to switch over to Obd1. i still need a p28 chipped and get it tuned using Hondata! i'ma run 10lbs. of boost...no more after that. </TD></TR></TABLE> you need 440cc injectors if running 10 psi , plus run saturated so you dont have to use the resisotr pack, and since your not running management should lower the boost or you'll go kaboom, also i have a set of brand new rc 550cc saturated injectors for sale asking 270.oo new still in plastic bubble bags
Old May 5, 2005 | 08:57 PM
CerealWars's Avatar
Are you going to turbo before you get the Hondata? If so, what are you going to use as your fuel management? As for the injectors when you get Hondata you should be just fine using them with the 15G and 10psi, but you will need to swap your OBDII (96-00) injector clips for some OBDI (92-95) clips.
suthernbred904
Oct 14, 2009 07:21 AM
00ek9civicjay
Apr 29, 2005 09:37 AM
00ek9civicjay
Apr 28, 2005 11:23 AM
phoQ
Mar 29, 2005 10:31 AM
DIY_Racing
Dec 21, 2002 09:16 AM
