power antennae replacement
if you look at top of power antenna there is a chrome nut, you need to remove nut put radio on and pull on antenna it will come off it is easier if someone helps...to install it put antenna in motor and have someone turn radio off make sure the teeth are aligned as the same way you took it out ,,if there is no broken antenna piece stuck in motor the new one will go all the way in ,,reinstall chrome nut ...if antenna will not go all the way in you need to remove motor, remove the back lid 3 screws . pull the plastic ring out and there should be a piece of broken antenna there ,,put motor bak together and then put antenna in like i explained before
