Integra GSR and CRX Si Hubs... they the same?
Old Apr 29, 2005 | 06:53 AM
Driven's Avatar
Default Integra GSR and CRX Si Hubs... they the same?
are 1994 Integra GSR and '90-91 CRX front hubs the same?
what about the bearings? they looked very similar when i had them apart.
Old Apr 29, 2005 | 07:01 AM
dr_latino999's Avatar
Default Re: Integra GSR and CRX Si Hubs... they the same? (Driven)
Nope, hubs are different. Now if you had the 90-91 EX hubs and said the same thing, I may be inclined to believe you.
Old Apr 29, 2005 | 11:59 AM
Driven's Avatar
Default Re: Integra GSR and CRX Si Hubs... they the same? (dr_latino999)
What's different? the spline count is the same. are the diameters for the knuckle different?
Hub, i mean, the part that has the wheel bearing surround it, has the wheel studs attached, and the rotor is screwed into.
the knuckle is the upright, which i know is different. the hub appears to be very similar in overall size and dimensions.
Old Apr 29, 2005 | 12:50 PM
All you have to do is measure out the bearings and if they are the same that is the answer.
delinquent
Nov 27, 2011 09:40 PM
92civicfreak
Mar 7, 2007 05:10 PM
Metal Typhoon
10
Feb 1, 2007 03:01 PM
Driven
May 5, 2005 04:57 PM
olddriver
Mar 16, 2002 05:17 PM
