Launching at 7k Rpm on 20 inch Slicks and bogging through 1st
i took my car to the track and i put about 12 PSI in the 20 inch mickey thompson slicks and was launching at about 4-5k rpms which is what i was doing on normal street tires but i was extremely bogging... so i went higher and higher but i just couldnt seem to get the ***** to leave the line at more than 7k. At 7k it would hook and leave the line like a bat out of hell but then bog down to about 4200-4400 rpms...I was thinking that leaving the line at 8k or 8200 would be perfect right in vtec but man is that scary dont want to break anything....need more tire pressure?
Ran 14.4 in 97 Coupe with JDM GS-R swap weighed in at 2650 i/h/e/ecu
you gotta have em spin like once or twice, then it will rocket to redline, and drop once you get traction......THEN BAM, redline again <---- this is your shiftpoint.
i know when you see the first redline, you think to shift then, but your tires are actually spinning, you need to wait it out.
( at least this was my first experience on slicks )
just practice, maybe one or two runs, hit the revlimiter to make sure that what i am telling you is what is truely happening to your car.
i have 20 in M/Ts too, and i had a 1.8 60 foot with them and no bogging at all, do you have a LSD or open diff?
phantom grip...i know i know but hey it actually works on street tires i cut .2 out of my 60ft just from the phantom grip regardless of what people say....what was your tire pressure?
15psi. Launch at redline. In an old LS/VTEC setup of mine that I had stock LS Rods CTR pistons w/ a GS-R head (only put down like 176whp up here) I used a P72 ECU and I would just take it up to 8100rpm and just BANG it off the rev limiter. I got the amount of spin I wanted and alway got consistant 1.8 sec 60' times with M&H 20 inchers. Even at 7000rpm I'm sure it would bog down to like 4500 or 5000rpm.
i ran 15 psi in my slicks, and didnt spin, but didint get the inital hook that i wanted, dropped them down to 12 psi (warm tires) and BUTTER!!
fungus mungus
Oct 28, 2011 10:25 PM
Cyber ITR
Apr 21, 2003 04:54 PM
