reverse mini me
i just want to know if the a6 head will fit on the z6 bottem end... its all gonna be obd0 i just want to know if anyone has ever tried this setup... i know im ghetto and lazy but i have all the crap layin around
im really going to get that low of comp? thats sweet the car is already turbo thats what produced the hole in the last block
wastegate got stuck closed. can you explain a little more about the oil control?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kTeg »</TD></TR><TR><TD CLASS="quote">what happens if i do nothing? its just going to squirt oil on the bottem of the headgasket right?</TD></TR></TABLE>
That doesnt sound safe, that oil is going to soak into the gasket, it will eventualy spread im sure. putting an A6 head on a z6 bottom to me isnt worth the trouble, sell the A6, and get a z6 head.
blah im gonna do it.. if it blows up im out what?? a shitty bottem end and a shitty head
besides 8comp sounds good 2 me. im sure i could tap it and put some kinda bolt in there. someone has to be as ghetto as me and have done this b4 lemme know
Peep this this! I can't post pics cuz my Vivitar is in the shop, but I am gonna post my latest swap. I call it Ridgeline Rex CRV 4WD.
It consists of the Honda Ridgeline 3.5L v6 with an auto to manual trans. swap and 4wd in the CRX body on a CRV frame with a 12 inch body lift and 8 inch suspension lift sittin on 52inch mickey thompsans.
It may just be the hottest swap on the market. I know it is gonna be pro-spec.
swap ya later.peace
swap ya later.peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX »</TD></TR><TR><TD CLASS="quote">u need to run the z6 block with an oil jet from a a6 block. then it should work.</TD></TR></TABLE>
Or an oil jet from any non-vtec block should work. Many people have done this before its called the no-tec swap. Basically it yields c/r of 8s. Which is perfect for boosting. usually the no-tec crowd get the more respect because of massive boost and not vtec. I give props as well.
From: A part of your daily REALITY..., in a state of DUB MUSIC Conciousness, and International Reggae Music SupaStar
Alohas,
I personally DON'T KNOW.....
But my peeps @ d-series.org do!!
go hit em up and see whassup!!
got nothing but Honda Love in da House!!
808AutoFashion
808AutoFashion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madswapper »</TD></TR><TR><TD CLASS="quote">
swap ya later.peace</TD></TR></TABLE>
..dubya tee ef?
EDIT*** http://www.knology.net/~jediklc/D.htm
your cr :8.609440997947613
using a
D16Z6 Block 75mmbore x 90mm stroke
D16A6 Head 38.00 Combustion Chamber Volume[cc per cylinder]
P28-A01[USDMD16Z6] Pistons -10.10 Dome Displacement [cc per piston]
D16Y8/Z6 HG 0.03700000 thickness
With an OEM D16z6/y8 piston to deck hieght.
I would imagine that to be fairly accurate, give a take a a few .XXs'. - Darrell
Modified by DOHCZCCRXSi at 6:30 AM 4/29/2005
..dubya tee ef?
using a
[quote/]Or an oil jet from any non-vtec block should work. Many people have done this before its called the no-tec swap. Basically it yields c/r of 8s. Which is perfect for boosting. usually the no-tec crowd get the more respect because of massive boost and not vtec. I give props as well.[/quote]
thanks a lot this should be interesting ill post some pics tonight the a6 is at the machine shop gettin cleaned right now
thanks for the spec lookup dohczccrxsi
Modified by 2kTeg at 10:21 AM 4/29/2005
i didn't find 2 much about it on that d-series site i actually only found one guy gettin flamed for tring it lol.. so if you know of a good link about it hook it up. Can i use a jet from a z6 head? or does it need to be from a non-vtec block?
well i found out that my a6 head that i was gonna use has 2 leaky valves.. im still going to do this though i just have to wait tell my other a6 head gets here sunday.. for the oil jet i used the z6 jet out of the head and put it into my z6 block all looks good it kinda sticks up a tiny bit though does that matter??
c/r with z6 head gasket(metal)= 8.609440997947613
c/r with crappy a6 headgasket= 8.43383096360439
ummm.....I dunno about that oil jet you don't want anything to interfer with your seal....I got an extra jet I just pulled out of my a6 block if you want that pm me....you could try replacing the valve stem seals in your leaky head....it isn't much money and you should be able to do it yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kTeg »</TD></TR><TR><TD CLASS="quote">for the oil jet i used the z6 jet out of the head and put it into my z6 block all looks good it kinda sticks up a tiny bit though does that matter??</TD></TR></TABLE>
That's normal.
That's normal.
