piston to wall clearance
Old Apr 28, 2005 | 06:32 PM
pomansouth01's Avatar
Ginger Kid
Default piston to wall clearance
Is anyone familiar with the piston to wall clearance of the toda b-series pistons, donf or others please chime in with your experience as well. Also does .02 to .03mm sound right for the proper clearance, this is what i have been told by toda, but that only works out to just over a thousanths of a inch of clearance, let me know!!
Old Apr 29, 2005 | 03:24 PM
Ginger Kid
Default Re: piston to wall clearance (pomansouth01)
bump it, i cant believe out of all these people who are so techincal, no one knows anything about piston to wall clearance.
Old Apr 29, 2005 | 04:20 PM
Rocket's Avatar
If you have a micrometer and can measure the cam and taper of the pistons I can help you.
I know Omni says that Toda's reccommend clearances are too tight.
Old Apr 29, 2005 | 08:36 PM
ericrx_88's Avatar
Default Re: piston to wall clearance (Rocket)
i would say more like .002-.003 not .02-.03
Old Apr 29, 2005 | 09:33 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">I know Omni says that Toda's recommend clearances are too tight.</TD></TR></TABLE>
Toda recommends 0.001", I called them to verify when I installed their pistons. They said that the material that the pistons are made with does not expand much. I went with 0.002", just to be safe.
Old Apr 29, 2005 | 10:36 PM
Ginger Kid
Default Re: piston to wall clearance (b19coupe)
well its bored to .0011" of clearance right now, thanks for chiming in when I need. The recommended clearances do seem a bit tight and I have called and confirmed a few times my self. They recommend .02-.03MM not inches. They are in conglomeration with honda which makes me think that they use something along the same lines as honda in their pistons. If you will check, hondas clearances are just about the same, real small like that. I was just kind of wondering if it would hurt to put another hone on it just for good measure. I would rather have enough room than too little, I dont want to tear this thing back apart after I put it in the car. .02 works out to .000778" which is skinnier than a sheet of paper. So I was thinking, the clearance should atleast be .04MM or .00157, which is just more than what Toda claims to be enough clearance. All who know something, chime in with advice.
Old Apr 30, 2005 | 04:35 PM
Ginger Kid
bump it again
Old Apr 30, 2005 | 06:38 PM
CRITTERMATT's Avatar
Default Re: (pomansouth01)
bump for some answers i am putting toda pistons in a GSR block and want to make sure everything is right.
Old May 11, 2005 | 07:58 AM
Ginger Kid
i talked to the machine shop and they said that the bore was stock spec for that piston, right where it should have been, but since one of my pistons cracked while trying to remove it from a oe rod, I have purchased the tried and trued srp's so i can run those crappy gappy clearances. anyhow, bump for this man some answers
Johnny_9
May 21, 2006 09:55 AM
itr_18
14
Jul 7, 2004 04:21 PM
itr_18
Apr 22, 2004 11:59 PM
black2001ITR
Nov 13, 2003 11:03 PM
ITR111
Sep 30, 2001 01:37 PM
