hi fellas, I need to make a list for my ls motor swap that i am planning to buy soon.
Old Apr 28, 2005 | 06:25 PM
4DRmafia's Avatar
Default hi fellas, I need to make a list for my ls motor swap that i am planning to buy soon.
what would i need to do to the wires ? change it to obd0 ? i know i will have to get a ecu for it too. since i already put an whole wiring from a si into my dx. So i bascally just want to drop the motor in my hatch along with hasport motor mounts of course. will the ls axles swap right in on my hubs ? i been told that i have to remove the dust rings to get them to fit in propertly. So fellas just tell me anything to me what i need to do or get to have this swap to work right on the 1st time. ohh also i dont know if this matters but the motor might be from an 1999 integra ls if that matters.
thanks agian,
Ron
Old Apr 28, 2005 | 06:57 PM
kurinto's Avatar
Default Re: hi fellas, I need to make a list for my ls motor swap that i am planning to buy soon. (SkipMic20
I should tell you to search as everything is extensively covered, but I'm putting off writing a paper so here goes...
You put the "whole wiring" from an si in? So you have everything converted to mpfi? You are fine then as far as wiring goes. It will be easiest to convert the engine to obd0. You need an obd0 mpfi distributor and an obd0 LS ecu. If you have an Si distributor that can be modified to fit I believe (correct me if I'm wrong).
You will want to put your converted mpfi engine harness on the engine. If you do indeed get a 99 LS engine you will need to extend some wires. For example, the ones to the cooling temp sensor. Some of the sensors on the Ls intake manifold are placed differently than the crx so you will need to extend some wires there. Go download a crx manual and an integra manual and look at the wiring diagrams and start matching everything up.
90-93 integra axles w/ half shaft and the dust rings removed should work.
You need a b-series shift linkage cut and welded, or if you like wasting money/ don't know anybody with a welder buy the hasport one.
The only thing that makes me feel somewhat good about this post is the hope that someone in the future will find it after searching and not need to make another thread. Well this is under the huge stretch of an assumption people will actually search...
Old Apr 28, 2005 | 07:41 PM
4DRmafia's Avatar
alright thanks man, u pretty much covered what i need to know ..and yeah my whole wireing is an si, i basically raped an wrecked si car and took all the wires and translate it on my dx hatch
then agian thanks alot
Old Apr 28, 2005 | 07:52 PM
kurinto's Avatar
Default Re: (SkipMic2006)
What transmission will you be using?
Old Apr 28, 2005 | 08:16 PM
4DRmafia's Avatar
not really sure ... i want the gears for the 1st to 4th to be quick then 5th good for highway driving is which i use everyday to school... i would like something similar to a d seris si tranny or something like that. and ofc i know it wont bolt up lol. so i want something short gearing and 5th for highway
Old Apr 29, 2005 | 05:54 PM
94civickid's Avatar
still lookin for an LS motor i got one if not that i'm selling with a JDM DC 4-1 header that has never ben used complete swap.
builtsinglecam
14
Jan 24, 2009 07:56 PM
chinegro
27
Feb 3, 2005 10:07 PM
Dropped90Integra
11
Nov 30, 2004 01:56 PM
HatchBox
Jan 6, 2003 02:53 PM
V8HAHA
Oct 5, 2001 04:07 PM
