Suspension & Brakes Theory, alignment, spring rates....
got my alignment done, check out my camber settings!
Old Apr 28, 2005 | 06:17 PM
Wazup's Avatar
Default got my alignment done, check out my camber settings!
front left: -1.2
front right: -1.4
rear left: -2.6
rear right: -2.4
hmmm.. rear camber kit needed? the toe is fine now of course, but im just wondering if i should worry about the camber now...
car is lowered about 1.3 inches
thanks
Old Apr 28, 2005 | 06:42 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: got my alignment done, check out my camber settings! (Wazup)
camber looks fine to me...
Old Apr 28, 2005 | 10:16 PM
suspendedHatch's Avatar
Put a washer or two on each of the four bolts on the rear.
More negative camber on the rear in general causes understeer at the limit. I would say something about excessive wear (depending on which tires), but that's taboo here on HT.
Old Apr 29, 2005 | 02:41 AM
Wazup's Avatar
Default Re: got my alignment done, check out my camber settings! (shaundrake)
could i just put the bolts and washers on, or would i have to get it aligned again afterward?
how many washers would you recommend?
Old Apr 29, 2005 | 06:29 PM
fireant's Avatar
Changing the rear camber will change your toe. I think two washers will be right on target for you, but depending on your drop you might want a little negative camber to clear the fender.
The front will be fine as long as the toe is zero.
Old Apr 29, 2005 | 08:10 PM
eMpAtHy's Avatar
my camber is about -1.3 degrees all around..
taquatch.
Suspension & Brakes
Feb 4, 2009 11:39 AM
EJK20R
Suspension & Brakes
Mar 19, 2006 10:26 PM
Andrew 825SM
Aug 15, 2003 03:16 AM
projectM
Mar 11, 2003 03:01 PM
rioninja
Aug 22, 2001 02:21 PM
