Upper collum alignment (pics)
Old Apr 28, 2005 | 06:08 PM
EnKidu's Avatar
Default Upper collum alignment (pics)
Since iI bought this I cannot use my right signal unless I push and hold it... I know the rack only goes in one way and the plastic the same... So I am assuming that I can adjust the upper portion to straiten this... anyone know how or is it something else? You can see the gap is bigger on the top right and the blinker almost touchs the plastic piece...
thanks guys...
[img=http://img175.echo.cx/img175/1986/collum3qq.th.jpg]
Modified by EnKidu at 7:43 PM 4/28/2005
Old Apr 28, 2005 | 06:34 PM
Aphelion's Avatar
Default Re: Upper collum alignment (EnKidu)
weird. I'd take it apart what you can and put it back together, chances are you'll see what you messed up. If that doesn't work, get a dremel and fix it like a man
Old Apr 28, 2005 | 06:45 PM
EnKidu's Avatar
Default Re: Upper collum alignment (Aphelion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aphelion &raquo;</TD></TR><TR><TD CLASS="quote">weird. I'd take it apart what you can and put it back together, chances are you'll see what you messed up. If that doesn't work, get a dremel and fix it like a man </TD></TR></TABLE>
yeah I dont want to bore it out if I dont have to.... someone has had to have take this apart before...
extremevtecracing
Mar 9, 2008 08:25 PM
efficiencyJunkie
59
Sep 25, 2007 03:32 PM
phoshizzle88
Feb 26, 2006 11:33 AM
DCFIVER
Feb 3, 2005 09:20 PM
92LudeSI
Sep 20, 2003 02:23 PM
