Type R radiator in GSR
Old Apr 28, 2005 | 05:02 PM
sinister357's Avatar
Default Type R radiator in GSR
can you guys comfirm that this radiator is JDM ITR radiator? notice how the edges aren't as rounded as in the GSR's and it's not brown in color.
Old Apr 28, 2005 | 05:07 PM
330R's Avatar
Default Re: Type R radiator in GSR (sinister357)
Well, it looks like an ITR radiator, but whether it's from the JDM...
Old Apr 28, 2005 | 05:12 PM
Default Re: Type R radiator in GSR (330R)
how can you tell? i mean what are the features on an R's radiator. i noticed my temp is cooler now also. wondering if it has anything to do with this radiator. as for JDM or not...just look at the throttle cable or something bracket bolted in the middle of the radiator. you got me???
Old Apr 28, 2005 | 05:15 PM
330R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister357 &raquo;</TD></TR><TR><TD CLASS="quote">as for JDM or not...just look at the throttle cable or something bracket bolted in the middle of the radiator. you got me???</TD></TR></TABLE>
yeah I see that in the pic now.. I had just referenced another RHD ITR pic before I saw your last post, and I see it in that pic, too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister357 &raquo;</TD></TR><TR><TD CLASS="quote">how can you tell? i mean what are the features on an R's radiator. i noticed my temp is cooler now also. wondering if it has anything to do with this radiator. </TD></TR></TABLE>
Features? hmm.. well, if you're comparing the wider Integra radiator to a narrow and skinnier Civic radiator, I'd say increased cooling capacity.
Are you using the same thermostat from before?
Old Apr 28, 2005 | 05:18 PM
itr1244's Avatar
both should work the same i assume...
JDM or USDM ITR rad.
Old Apr 28, 2005 | 05:28 PM
Default Re: Type R radiator in GSR (itr1244)
yeah, i using the same thermostat and i think camparably sized radiator. nothing else changed. now my temp guage only goes 1/8 of the was as conpared to 1/4 to almost 1/2 as before. not that i'm complaining but...
Old Apr 28, 2005 | 05:39 PM
330R's Avatar
Make sure the fan isn't running all the time. Is the engine idling higher?
Also run the heater full blast after the car has warmed up and see if you get hot air.
Cowl287
Aug 1, 2008 03:19 PM
sinister357
Apr 17, 2005 12:46 PM
reno96teg
Aug 18, 2004 07:51 PM
