97 Honda accord Wheel studs Question?
Old Apr 28, 2005 | 04:57 PM
tjohnson329's Avatar
Default 97 Honda accord Wheel studs Question?
I have a 97 honda accord and my front left wheel stud broke off. I am currently drivng the car with three studs but would like to replace the other one. i calle dhonda and they said that it would cost me $5 for the lug nut and stud but cost $130 for the labor. I want to do this in my back yard but need to know if i need to do anything special like pressing the hub. If someone could answer this real quick that would be great. thanks
Old Apr 29, 2005 | 06:08 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 97 Honda accord Wheel studs Question? (tjohnson329)
when I replaced my wheel studs on my 95 EX, I was replacing the rotors as well so it was easy to remove all the studs and press in new ones since I had the hub removed. I have been told though, that you can remove the caliper and caliper bracket and then you should have room to pop the old stud out the back with a pumch and a hammer and then place the new one back it. Then you can place a few washers on the stud and put your lug nut on and tighten it down. That should pull the stud all the way into place.
Old Apr 30, 2005 | 03:14 AM
Default Re: 97 Honda accord Wheel studs Question? (TouringAccord)
oh thanks cause at first when honda told me how much it cost they said that I would need a press to put a stud on. I didn't think I did so thank you for the info. By the way how long do you think it will take for me to put it on?
Old Apr 30, 2005 | 05:38 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjohnson329 &raquo;</TD></TR><TR><TD CLASS="quote"> By the way how long do you think it will take for me to put it on?</TD></TR></TABLE>
If you've never done it before, probably a good part of the day.
Old Apr 30, 2005 | 07:29 AM
st95accord's Avatar
When i replaced the wheel studs i just punded them out with a hammer and they fell out the back of the rotor. then i just slipped in the new ones and used a philips head as a pick to hammer them in.
taxman49
Jun 1, 2013 09:38 AM
tracychase
Sep 30, 2012 05:28 PM
marvin75
Apr 24, 2011 05:48 AM
Erics 96 NSX T
Mar 17, 2011 04:34 PM
tubular031
Apr 27, 2008 12:17 PM
