Pro Drive hubs and Gator Axles
Old Apr 28, 2005 | 03:12 PM
hndarcrb18c1's Avatar
Default Pro Drive hubs and Gator Axles
Everytime i drive the car it distroys the wheel berings any suggestions/comments???
Old Apr 28, 2005 | 04:28 PM
Kataku2K3's Avatar
Default Re: Pro Drive hubs and Gator Axles (hndarcrb18c1)
That's really strange, we've never had a problem with "power" taking out wheel bearings... Actually, I doubt that's the case but I could be wrong. What are you torquing your spindle nuts to?
Old Apr 28, 2005 | 05:27 PM
Default Re: Pro Drive hubs and Gator Axles (Kataku2K3)
Naa its not the "Power" as soon as I drive the car around the block I jack it back up and the and the whole wheel/ hub shakes
Old Apr 28, 2005 | 05:58 PM
Kataku2K3's Avatar
Oh I see, I misinterpreted what you said the first time... I figured you were saying "every time you drive the car at the track" You sure you're working with the right bearing/hub combo?
Old Apr 28, 2005 | 06:10 PM
Im looking into that now I have the "EARLY" style hubs with 36mm splines but it uses a civic wheelbering... Stan from fast. is gonn look up my invioce tommrow and find out with axles I orderd I think i just got the stage 3's with prelude outter wich would be the problem... I just figured I throw a post out here to see if anyone has experinced the same prob....
Old Apr 28, 2005 | 06:13 PM
SEFIxCivic's Avatar
did you put a washer before you put on the axle nut? if you didn't you need one.
Old Apr 28, 2005 | 06:16 PM
Default Re: Pro Drive hubs and Gator Axles (SEFIxCivic)
Yeah, I tried that also. still no go the Axle is bottomed out into the hub I think I just have the wrong axles...
alex1320
Mar 6, 2013 08:47 AM
Cynical 1
Suspension & Brakes
Jan 17, 2011 06:00 PM
418whpturboD
Oct 27, 2008 02:55 PM
stealth_EK4
Suspension & Brakes
Aug 21, 2005 09:35 PM
Aggressive Racing
Nov 22, 2004 06:12 PM
